 Post subject: faulty HDD has lost its capacity from 3TB to 800GB
PostPosted: October 18th, 2018, 7:46
I have a HDD which for some unknown reason decided to brick, loose all data on it,
when i have plugged it back into my windows pc and opened disk management, it has dramatically lost its capacity from 3TB to 800GB, and their is only one partition, no unused partitions,
is thier a way of fixing this ?
many thanks in advance,
Stuart
 Post subject: Re: faulty HDD has lost its capacity from 3TB to 800GB
PostPosted: April 24th, 2019, 2:44
1. I believe your drive was INSIDE EXTRNAL CHASIS
Is it?
2. Your drive was plugged in under WinXp.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: April 24th, 2019, 4:35
Your SATA driver has a 32-bit LBA limit. You need to update your driver (eg Intel RST) or select AHCI mode for your SATA controller in BIOS.
