 Post subject: Burnt/Fried PCB "WD 4TB My Book" (WD40EZRX-00SPEB0)
PostPosted: May 3rd, 2019, 7:01
Hello friends,
I moved my PC setup around and made the stupid mistake of connecting the incorrect adapter to my (then) external hard drive.
I got my system on and was messing around on the other side of the room when it smelt like something was burning and I turned everything off, once I couldn't find the source, I slowly started turning things on again and realized my 4TB WD My Book was no longer being read by my PC and for a brief period saw smoke coming out.
I finally realized I was using a 50VOLT PSU for my drive instead of the 12WATT PSU it came with, but the damage has been done. I tried using the correct PSU but the power light wouldn't come on anymore.
I extracted the hard drive from its case and tried directly connecting to my PC PSU with sata but had no luck, it has no signs of life when my PC posts and looking in the BIOS, it has no indication that a hard drive is connected to the sata slot. I'm guessing that the PCB is fried.
is there anything I can do to the PCB to allow me to power up the drive and transfer some data?
I haven't unscrewed the PCB off the hard drive yet because I'm not sure what I'd even do once that's done... I've heard that you could pull out the diode near the power connector to get it running for a limited time...?
Money is tight as of now, sadly it's not an option to send it to a professional in the immediate future.
The hard drive itself can rot for all I care, but it really is in my interest to get some stuff off there (only ~3gb worth) so it doesn't need to work for long.
Thank you for your time!
appreciate any help regarding this :)
 Post subject: Re: Burnt/Fried PCB "WD 4TB My Book" (WD40EZRX-00SPEB0)
PostPosted: May 3rd, 2019, 17:37
Upload detailed photos of both sides of each PCB (HDD PCB and USB-SATA bridge PCB).
Be prepared for this:
Catastrophic failures in Western Digital PCBs:
http://www.hddoracle.com/viewtopic.php?f=100&t=2169
PostPosted: May 3rd, 2019, 17:44
When you do get around to accessing your data (with @fzabkars help) you might find that the data was encrypted through the USB bridge board (depending on age of the unit). There are ways around this also.
PostPosted: May 3rd, 2019, 19:35
Side 1 HDD PCB:
Side 2 HDD PCB /w buffer:
Side 2 HDD PCB w/o buffer:
Side 2 HDD PCB showing burn area:
I drew a line connecting the burn, the material is discolored slightly on it's an entire edge but the source of the burning is right there.
Side 1 USB-SATA bridge PCB
Side 2 USB-SATA bridge PCB
Thank you
I see, thank you. The drive was bought in 2015. If I can get the HDD reading on my PC I'll cross that bridge when I get there.
Spildit wrote:
snip
Thank you for the insight, what do you make of the situation now that the photos are available?
PostPosted: May 4th, 2019, 18:58
So I've gone ahead and used a multimeter to verify that D4 TVS was shorted and removed it, now the D4 pads on the PCB give me a healthy reading
Sadly this did not allow me to connect via internal PC PSU and SATA, there is still no spin on power-up. I've read from fzabkars' great posts that sometimes the zero-ohm resistors sometimes needs to be jumped but I'm not sure where that's located on my PCB or how to do it.
I did some reading on the USB-SATA bridge PCB and both U5 and U4 have visible burns (also visible in the picture) but U5 still reads as a healthy diode, but U4 top 4 pins (where the burn is visible) reads shorted, 0.03. Contemplating snipping that out to see if power can start to be supplied via the USB unit, but I feel like I'm missing a step.
PostPosted: May 4th, 2019, 19:14
R60 (zero-ohm resistor) on the HDD PCB is probably open circuit. If so, you can bridge it with a blob of solder, as long as there is no other damage. This is one PCB where WD's protection circuitry has a good chance of working.
The USB-SATA bridge board has a damaged 5V regulator (U5) and a damaged MOSFET power switch (U4). IMO it would be easier for you to replace this PCB. (There is a potential zero-cost workaround, but you would need tech skills to implement it.) Alternatively, you could use a free tool ("reallymine") to decrypt the HDD directly via SATA.
http://www.hddoracle.com/viewtopic.php?f=22&t=1488
PostPosted: May 4th, 2019, 19:36
When you say bridge R60 with a blob of solder, do you mean something like this with the blob running from R60 to R43?
Also is there any specific type of solder I should use or does it not matter?
Alrighty I'll put the USB bridge out of sight for now, thank you for the link if I can get the drive reading by my PC SATA I'll explore my options on that then.
Spildit wrote:
If repairing the PCB of the HDD turns out to be impossible you need to buy a PCB with the same number 2060-771945-002 or 771945-E02 and you need to either move the ROM chip at position U12 (the windbond flash memory) from the damaged PCB to the newer one or if you can't solder you need to read the rom content using a programmer and SOIC 8 clip and write it to the new donor PCB like this :
http://www.hddoracle.com/viewtopic.php?f=110&t=1738
as very cheap alternative you can buy this :
http://www.hddoracle.com/viewtopic.php?f=110&t=1040
It's very cheap on eBay and will do the job without soldering. It works just fine on your WD PCB. Drivers for programmer are on my site as well.
If you do replace the PCB or repair the PCB and the drive does click and spin down or just click like mad then the overvoltage did kill the pre-amp inside the drive and you will need clean room work - EXPENSIVE - and it's no longer a do-it-yourself project.
But because most likely the protection on your PCB did work your pre-amp most likely did survive ... I did saw many PCBs where the pre-amp was killed and on those normaly the motor controller IC does get visible damaged as well ...
Thank you much for the links and info, I'm hoping I can make this a simple fix with my current PCB, but once I've exhausted trying to get the OG working I'll start planning finding a donor PCB.
I'm not averse to soldering, I've redone the electronics on a guitar a few times, we'll see.
PostPosted: May 4th, 2019, 19:37
ect: [R60]-solder-[R43]
Users browsing this forum: Google [Bot] and 65 guests
