 Post subject: SCV32 (Galaxy A8) where is the memory chip?
PostPosted: May 27th, 2019, 4:23
Hi guys!
Have a dead SCV32 (Galaxy A8).
Of course there are a lot of options before chip-off as repairing and what not,
but at the moment wondering where the memory chip is?
On S6 it is above Shannon 333 baseband (to the left from CPU), but this time it is just empty space.
Is it inside CPU Exynos 5433?
Searched the WEB, no info.
Please advise...
 Post subject: Re: SCV32 (Galaxy A8) where is the memory chip?
PostPosted: May 27th, 2019, 5:16
What is that Samsung IC to the left of the Exynos CPU?
PostPosted: May 27th, 2019, 15:02
Looks like the prime candidate to me, although it’s difficult to tell without a decent photo.
PostPosted: May 27th, 2019, 17:30
It's not the same PCB, but it has a Samsung KMQ310013M eMCP (EMMC+LPDDR3 16GB+2GB).
Samsung Galaxy A8 Teardown:
http://www.myfixguide.com/manual/samsung-galaxy-a8-teardown/
PostPosted: May 27th, 2019, 23:37
Uploaded some more photos.
And found this...without any new info about the memory
https://fccid.io/A3LSCV32/Internal-Phot ... to-2818832
PostPosted: May 27th, 2019, 23:53
thank you for the info - yes, I think it is a worldwide variation, and in my case where should be eMCP is empty space, only modem Shannon333
PostPosted: May 28th, 2019, 2:51
There is some physical damage around one of the power management ICs. Could it possibly be an easy fix?
PostPosted: May 28th, 2019, 4:20
The processor and eMCP are stacked on top of each other.
https://www.techinsights.com/blog/samsung-galaxy-note-4-alpha-teardown
PostPosted: May 28th, 2019, 6:59
Thanks so much!
Will try to find this reader
https://www.amazon.com/dp/B07BTZQZZ1
PostPosted: May 28th, 2019, 7:25
What is the model of Exynos chip?
We had similar device in lab.
If you need any help with pinout just let me know at: patryk@rusolut.com.
PostPosted: May 28th, 2019, 17:33
Why not fix the damage instead of a chip-off, or did you damage the PCB while removing the PMU cover?
There should be two part numbers on the multi-chip. One is the CPU (5433), the other is the eMCP.
Users browsing this forum: No registered users and 17 guests
