Forum rules
 Post subject: Has anyone figured out the JTAG pins on a Seagate LSI chip ?
PostPosted: June 11th, 2015, 17:27
I am trying to figure out the JTAG pins on an LSI Seagate processor.
The board I am working on is a 100535704 Rev C from a 7200.12 drive
I chose this board because it has 2 sets of header pads on the pcb --
1 is 20 pads and the other is 38 pads (also has 18 pads for the MHA)
Nothing seems to make sense on these pads
Only 3 of the pads have anything that could be a clock, but they are
pulses, not a square wave, either 30 or 60 microseconds with a 3-4uS pulse
The MPU is a LSI SEAGATE B5502D0 - 176 pin IC
 Post subject: Re: Has anyone figured out the JTAG pins on a Seagate LSI ch
PostPosted: June 11th, 2015, 21:19
you need a JTAGulator!
PostPosted: July 17th, 2015, 1:03
PCB: 100535704
MPU: B5502D0
CPU ID: 0x25966041
JTAG PIN MPU PIN
TRST -> 16
TDI -> 18
TMS -> 20
TCK -> 17
TDO -> 19
PostPosted: July 17th, 2015, 3:35
nice, thanks kostyafil :)
PostPosted: July 18th, 2015, 1:34
But there is one problem.
The CPU does not go into "halt"
PostPosted: July 20th, 2015, 9:38
kostyafil wrote:
PCB: 100535704
MPU: B5502D0
CPU ID: 0x25966041
JTAG PIN MPU PIN
TRST -> 16
TDI -> 18
TMS -> 20
TCK -> 17
TDO -> 19
Do you have any link or could you post a description of how you figured this out?
- George
PostPosted: July 20th, 2015, 9:40
I've seen some systems which will not halt once it's running, but will only halt when it's reset via a "reset halt". On such a system, it only works if you can find the SRST line. Which is why I'm curious how you figured out the TRST line, but not the SRST line.
- George
PostPosted: July 24th, 2015, 7:47
http://www.ejtag.ru/viewtopic.php?f=8&t=49
It is possible that not all the signals I found.
PostPosted: June 2nd, 2019, 12:42
how about the JTAG pins for either of these:
PCB: 100617465 REV B MCU: B66508
PCB: 100687658 REV C MCU: B69002V0
PostPosted: June 2nd, 2019, 22:31
I have no experience with JTAG. That said, I would trace the signal pins at J6 and J104 back to their corresponding MCU pins. Hopefully there will only be a single group of 5 consecutive MCU pins. These would be your most likely JTAG candidates. Then you would only need to JTAG-ulate this group ???
PostPosted: June 6th, 2019, 13:50
so i am able to jtag to the board, but cant find the SRST line to reset or halt the processor
has anyone been able to reset or halt via JTAG ?
if it were "normal" RESET should be on pin 9 of the mictor header, but it seems this is not normal.....
refs:
https://developer.arm.com/docs/dui0499/ ... 38-pinouts
https://www.segger.com/products/debug-p ... 8-adapter/
Users browsing this forum: No registered users and 106 guests
