Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Accessing/Modifying/Dumping M36L0T05 Flash Contents
PostPosted: June 22nd, 2019, 12:53
small detail, but the MCP (multi chip package) has 2 parts, flash and PSRAM. There are different actual part numbers for each, and the flash part is
http://www.datasheetcatalog.com/datasheets_pdf/M/3/0/L/M30L0R7000B0.shtml
We actually discussed this last year: http://forum.hddguru.com/viewtopic.php?f=10&t=37167&p=262087 and I've been working on reading a similar chip. As I remember these chips are pretty small, smaller than it looks on the pics.
just going over this again I see I've missed a very important detail. I was under the assumption that the FlashCat pro did everything the other FlashCats did. I see the developers actually told me the XPORT should support it, and looking at spec pages for each device, seems with all the FlashCats I have, I don't have the right one. I am ordering the XPORT, I already have level shifters.
PostPosted: June 24th, 2019, 2:00
So my unit arrived and it is slightly different mainboard. Holds a single Spansion S29GL256P10TFI01 chip. Datasheet:
Spansion-S29GL256P10TFI01 .pdf [2.67 MiB]
Downloaded 1339 times
PostPosted: June 24th, 2019, 3:00
So your Spansion part is flash only whereas the OP's part is flash + PSRAM? This would suggest that the RAM is not used, or perhaps the blobs are not same (your blob may have on-chip RAM while the OP's may not).
PostPosted: June 24th, 2019, 11:06
I don't think the RAM is used. It may be possible to tell once more is worked out on the OP's board, such as if any connections to the flash that would be RAM only are missing, or tied to just flash.
Here is another teardown of a similar console. https://hackaday.io/project/27204-fake-nes-classic-edition-teardown
It uses a Spansion Flash as well. This one has a difference in the controller cable, only 4 wires. Also there is 2 pads that could possibly be the same as the pads between the CPU and crystal Osc labelled J1 and J2. they appear to be hard wired together with the trace. I looked closer at ours and I think they are actually connected with traces to ground plane as well.
Im guessing under the blob, a pretty basic FPGA is used, as this seems most popular for this application, and CFI memory interfacing is common. Maybe a Xilinx, Atmel or Freescale. This document outlines interfacing a S29GL :
freescale.pdf [430.57 KiB]
Downloaded 1256 times
PostPosted: June 24th, 2019, 17:23
freescale.pdf
Is there anything I can do to assist you in this?
PostPosted: June 24th, 2019, 20:07
I'm curious about the power supplies. Where is the 3.3V (and 1.8V ?) supply generated?
PostPosted: June 25th, 2019, 0:36
It is supplied by a 5v brick with USB Mini-B connector. if the circuit on the Mainboard doesn't do it, maybe more is done in the Processor itself. It is an extremely sparse circuit. Here is a better photo of the area
PostPosted: June 25th, 2019, 2:22
Q2 appears to be a 3.3V LDO regulator, although its circuit reference is that of a transistor. It seems inadequate for the job.
Q1 appears to be buffering the video output.
The 4-wire cable seems bodgy. It is bad practice to share a common ground conductor between power and signal pins. AV ground and power ground should be separate runs.
PostPosted: June 29th, 2019, 9:51
The attachment freescale.pdf is no longer available
I'm wondering what is under the memory addon board. possibility of another package pads under there in a similar way as this SD Card has 2 possible package types.. if a TSOP48 was soldered on, you wouldn't know about the circuit for the TLGA under there.
if there is an unpopulated set of pads, it may be possible to trace back to the memory board.
because this board would be easy to solder back on, maybe you could de-solder it and have a look what is under it?
Last week I ordered a FlashCatUSB XPORT and a tsop56 adapter to read the Spansion on my board. I also ordered 2 more units of the game for testing, as I found some cheap, and it will be useful in any case if they are all slightly different or the same.
And I also found a socket manufacturer that can custom make sockets, so I ordered a BGA88 socket with .08 pitch and got them to custom make a limiter for the chip size 8mm x 10mm, as usually BGA88 and .08 pitch is a chip with dimensions 11mm x 13mm.
I am working on a PCB for this socket in AutoTRAX DEX software to make it easy to use taking into account the level converters for the 1.8v these chips, as the FlashCatUSB is 3.3v or 5v
I know my chip isn't BGA88, but I do have an ongoing project that does have one - a chip from an old LG phone
PostPosted: June 29th, 2019, 20:15
XC6206P332MR, Torex, LDO regulator, 3.3V, 200mA, marking 662x, SOT-23:
https://www.torexsemi.com/file/xc6206/XC6206.pdf
PostPosted: June 29th, 2019, 20:48
so If 1.8v is needed somewhere, do they do this by a dodgy resister voltage divider? or maybe the IC that runs it is so "good" (meaning it is a very purpose oriented IC for this type of application that handles video and audio plus the basic processing for emulation for the ROMs) that it does the 3.3v - 1.8v stepdown..
BTW I don't know electronics as well as Franc, so not sure if voltage dividers are dodgy or quite fine
PostPosted: June 29th, 2019, 21:29
Voltage dividers are generally only used for voltage sensing. They cannot be used as voltage supplies. As soon as you start drawing current from a voltage divider, its output voltage plummets.
Another bodgy aspect of the circuit is that there are no small bypass capacitors adjacent to the flash chip's supply pins.
Edit: I believe that a nominal 1.8V supply is derived from the 3.3V supply by dropping the voltage by 1.2V via diodes D1 and D2. Another bodge ...
This would suggest that your "blob" doesn't require a 1.8V supply.
PostPosted: June 29th, 2019, 22:40
@HaQue, I should clarify my previous post by saying that the OP's circuit requires 3.3V and 1.8V whereas yours needs only 3.3V. This is because diodes D1 and D2 are populated on the OP's PCB but not on yours.
PostPosted: June 30th, 2019, 1:16
That would make sense as @mgysgthath's memory chips need a 1.8v supply and mine are 3.3v
So we probably can deduce a little more about each circuit knowing this supply trace
PostPosted: July 10th, 2019, 2:47
UPDATE:
I received a few things. 1 of the consoles, I think same as OP's luckily.
NOR Removed:
I also received the new FlashCatUSB XPORT, some level converters and the BGA-88 socket:
I will be able to read the Spansion NOR tonight I think, and I will also be making a PCB for the BGA-88 Socket to use on the FlashCatUSB, and do the level conversion, so I don't have to rewire everything all the time. I made a Mock-up in Paint to show how I think it will look:
PostPosted: July 10th, 2019, 8:33
I read the Spansion S29GL256P10TFI01 TSOP-56 NOR Flash without incident. Binary dump is 32MB, 7zip'd file is 12.2MB :
File comment: Spansion S29GL256P10TFI01 TSOP-56 NOR Flash Dump
Cypress_S29GL256P_00-01FFFFFF.7z [12.28 MiB]
Downloaded 1191 times
PostPosted: July 10th, 2019, 10:03
Nice job.
PostPosted: July 10th, 2019, 10:37
ddrecovery wrote:
Nice job.
Thanks. Makes it easy when someone creates a nice tool like the FlashCatUSB!
I installed binwalk and all dependencies on the Linux Sub system on a Win10 laptop.
I ran the dump through binwalk, though I expect a lot of false positives because this probably isn't actual firmware (Guessing that would be flashed to the FPGA/CPLD/or whatever processor is in the blob)
I have only given the output a quick scan, but interesting copyright notices!
I am guessing that this flash just contains a bunch of ROMs, and there may be some more analysis by finding a ROM file the same as one in the flash, carving it to see what the file format is. maybe can carve out the rest of the ROMs and see whats left. May be possible to flash more in there or switch ROMs or others, or even just get it to display something cool.
There could be something in the flash that can help ID what is under the blob as well.
root@Laptop01:/mnt/c/linux_share/nes# binwalk Cypress_S29GL256P_00-01FFFFFF.bin > binwalk.txt
DECIMAL       HEXADECIMAL     DESCRIPTION
211182        0x338EE         MySQL MISAM index file Version 1
295506        0x48252         Boot section Start 0x2020201 End 0x2020202
295510        0x48256         Boot section Start 0x2020202 End 0x0
311864        0x4C238         Boot section Start 0x42424242 End 0x10202
311868        0x4C23C         Boot section Start 0x10202 End 0x0
311872        0x4C240         Boot section Start 0x0 End 0x0
327849        0x500A9         Boot section Start 0x0 End 0x0
328241        0x50231         Boot section Start 0x1010101 End 0x201
328245        0x50235         Boot section Start 0x201 End 0x0
464222        0x7155E         MySQL MISAM index file Version 1
658875        0xA0DBB         MySQL ISAM compressed data file Version 6
698354        0xAA7F2         Boot section Start 0x0 End 0x0
703690        0xABCCA         Boot section Start 0x3010000 End 0x202
704322        0xABF42         Boot section Start 0x42424242 End 0x7E
704330        0xABF4A         Boot section Start 0x0 End 0xC080
704354        0xABF62         Boot section Start 0x42424242 End 0x7E
704362        0xABF6A         Boot section Start 0x0 End 0x3C00
721130        0xB00EA         Boot section Start 0x11040102 End 0xFF4F
727490        0xB19C2         Boot section Start 0x0 End 0x0
731282        0xB2892         Boot section Start 0x42424242 End 0x7E
756730        0xB8BFA         Boot section Start 0x0 End 0x73A0
756986        0xB8CFA         Boot section Start 0x-40000000 End 0x34B0
757194        0xB8DCA         Boot section Start 0x0 End 0x0
757450        0xB8ECA         Boot section Start 0x0 End 0x0
757482        0xB8EEA         Boot section Start 0x0 End 0x-1000000
757706        0xB8FCA         Boot section Start 0x0 End 0x0
761098        0xB9D0A         Boot section Start 0x4040404 End 0x980404
761850        0xB9FFA         Boot section Start 0x0 End 0x0
764666        0xBAAFA         Boot section Start 0x-3D2F1B2E End 0xC0C8
764922        0xBABFA         Boot section Start 0x880044 End 0x2002
765178        0xBACFA         Boot section Start 0x800140 End 0x0
765386        0xBADCA         Boot section Start 0x0 End 0x0
765642        0xBAECA         Boot section Start 0x0 End 0x0
765674        0xBAEEA         Boot section Start 0x0 End 0x-1000000
765898        0xBAFCA         Boot section Start 0x0 End 0x0
767130        0xBB49A         Boot section Start 0x-40C7EC79 End 0x15839
772858        0xBCAFA         Boot section Start 0x-1 End 0xFFFF
773114        0xBCBFA         Boot section Start 0x-100 End 0xFFFF
773770        0xBCE8A         Boot section Start 0x0 End 0x1F000000
777866        0xBDE8A         Boot section Start 0x0 End 0x-8000000
779258        0xBE3FA         Boot section Start 0x0 End 0x0
993958        0xF2AA6         MySQL MISAM compressed data file Version 7
1030120       0xFB7E8         Boot section Start 0x0 End 0x0
1034006       0xFC716         MySQL ISAM compressed data file Version 6
1262278       0x1342C6        MySQL ISAM compressed data file Version 6
1508914       0x170632        MySQL MISAM compressed data file Version 7
1515630       0x17206E        MySQL MISAM index file Version 3
1529746       0x175792        MySQL MISAM compressed data file Version 7
1536630       0x177276        MySQL MISAM compressed data file Version 3
1548614       0x17A146        MySQL MISAM compressed data file Version 7
1549670       0x17A566        MySQL MISAM compressed data file Version 7
1711342       0x1A1CEE        MySQL MISAM compressed data file Version 7
1728078       0x1A5E4E        MySQL MISAM compressed data file Version 7
1770676       0x1B04B4        MySQL MISAM compressed data file Version 7
1777502       0x1B1F5E        MySQL ISAM compressed data file Version 8
1841400       0x1C18F8        Boot section Start 0x0 End 0x0
1841656       0x1C19F8        Boot section Start 0x0 End 0x0
1841912       0x1C1AF8        Boot section Start 0x0 End 0x0
1842168       0x1C1BF8        Boot section Start 0x0 End 0x0
1889470       0x1CD4BE        MySQL ISAM compressed data file Version 4
1904254       0x1D0E7E        MySQL MISAM index file Version 6
1943150       0x1DA66E        MySQL MISAM compressed data file Version 5
1980960       0x1E3A20        MySQL MISAM compressed data file Version 7
1995878       0x1E7466        MySQL ISAM compressed data file Version 2
2104201       0x201B89        MySQL ISAM compressed data file Version 6
2116088       0x2049F8        MySQL ISAM compressed data file Version 6
2147553       0x20C4E1        MySQL ISAM compressed data file Version 6
2193824       0x2179A0        MySQL ISAM compressed data file Version 4
2202306       0x219AC2        MySQL ISAM compressed data file Version 6
2210126       0x21B94E        MySQL MISAM compressed data file Version 11
2222088       0x21E808        MySQL MISAM compressed data file Version 7
2232710       0x221186        MySQL MISAM compressed data file Version 3
2353782       0x23EA76        MySQL MISAM index file Version 7
2353814       0x23EA96        MySQL MISAM index file Version 5
2354038       0x23EB76        MySQL MISAM index file Version 7
2410285       0x24C72D        MySQL ISAM compressed data file Version 2
2413070       0x24D20E        MySQL MISAM compressed data file Version 7
2492539       0x26087B        Intel x86 or x64 microcode, sig 0x70010003, pf_mask 0x3fe02103, 1DE7-03-07, rev 0x-7081f900, size 2088700
2496635       0x26187B        Intel x86 or x64 microcode, sig 0x70010003, pf_mask 0x3fe02103, 1DE7-03-07, rev 0x-7081f900, size 2088700
2500731       0x26287B        Intel x86 or x64 microcode, sig 0x70010003, pf_mask 0x3fe02103, 1DE7-03-07, rev 0x-7081f900, size 2088700
2504827       0x26387B        Intel x86 or x64 microcode, sig 0x70010003, pf_mask 0x3fe02103, 1DE7-03-07, rev 0x-7081f900, size 2088700
2513019       0x26587B        Intel x86 or x64 microcode, sig 0x70010003, pf_mask 0x3fe02103, 1DE7-03-07, rev 0x-7081f900, size 2088700
2517115       0x26687B        Intel x86 or x64 microcode, sig 0x70010003, pf_mask 0x3fe02103, 1DE7-03-07, rev 0x-7081f900, size 2088700
2521211       0x26787B        Intel x86 or x64 microcode, sig 0x70010003, pf_mask 0x3fe02103, 1DE7-03-07, rev 0x-7081f900, size 2088700
2537595       0x26B87B        Intel x86 or x64 microcode, sig 0x70010003, pf_mask 0x3fe02103, 1DE7-03-07, rev 0x-7081f900, size 2088700
2540949       0x26C595        MySQL MISAM index file Version 1
2549883       0x26E87B        Intel x86 or x64 microcode, sig 0x70010003, pf_mask 0x3fe02103, 1DE7-03-07, rev 0x-7081f900, size 2088700
2787241       0x2A87A9        MySQL ISAM compressed data file Version 6
2910614       0x2C6996        MySQL MISAM compressed data file Version 7
2922294       0x2C9736        MySQL MISAM compressed data file Version 1
2922358       0x2C9776        MySQL MISAM compressed data file Version 3
2954718       0x2D15DE        MySQL MISAM index file Version 3
3026662       0x2E2EE6        MySQL ISAM compressed data file Version 6
3032510       0x2E45BE        MySQL MISAM compressed data file Version 7
3044701       0x2E755D        MySQL ISAM compressed data file Version 8
3049988       0x2E8A04        Boot section Start 0x3C3C3C3C End 0x0
3134382       0x2FD3AE        MySQL MISAM compressed data file Version 3
3134974       0x2FD5FE        MySQL ISAM compressed data file Version 4
3162534       0x3041A6        MySQL MISAM index file Version 3
3165306       0x304C7A        Boot section Start 0x-1 End 0xF0FF
3232422       0x3152A6        MySQL MISAM index file Version 5
3254454       0x31A8B6        MySQL MISAM index file Version 3
3256502       0x31B0B6        MySQL MISAM compressed data file Version 3
3392242       0x33C2F2        Boot section Start 0x0 End 0x0
3393522       0x33C7F2        Boot section Start 0x0 End 0x0
3394846       0x33CD1E        MySQL MISAM compressed data file Version 7
3424114       0x343F72        Boot section Start 0x0 End 0x0
3461634       0x34D202        Boot section Start 0x0 End 0x0
3462642       0x34D5F2        Boot section Start 0x0 End 0x0
3463682       0x34DA02        Boot section Start 0x0 End 0x0
3464690       0x34DDF2        Boot section Start 0x0 End 0x0
3465730       0x34E202        Boot section Start 0x0 End 0x0
3466738       0x34E5F2        Boot section Start 0x0 End 0x0
3467778       0x34EA02        Boot section Start 0x0 End 0x0
3468786       0x34EDF2        Boot section Start 0x0 End 0x0
3501218       0x356CA2        Boot section Start 0x0 End 0x0
3501474       0x356DA2        Boot section Start 0x0 End 0x0
3503430       0x357546        MySQL ISAM compressed data file Version 6
3519390       0x35B39E        MySQL MISAM index file Version 3
3520146       0x35B692        Boot section Start 0x0 End 0x1010000
3543742       0x3612BE        MySQL MISAM compressed data file Version 9
3580626       0x36A2D2        Boot section Start 0x0 End 0x0
3585874       0x36B752        Boot section Start 0x0 End 0x0
3588897       0x36C321        MySQL ISAM compressed data file Version 6
3599090       0x36EAF2        Boot section Start 0x0 End 0xE1F0000
3633042       0x376F92        Boot section Start 0x-42424243 End 0xFF81
3635090       0x377792        Boot section Start 0x-42424243 End 0xFF81
3679238       0x382406        MySQL ISAM compressed data file Version 6
3790772       0x39D7B4        Boot section Start 0x742074 End 0x6000C023
3834734       0x3A836E        MySQL MISAM compressed data file Version 7
3887385       0x3B5119        MySQL ISAM compressed data file Version 6
3920153       0x3BD119        MySQL ISAM compressed data file Version 6
3938638       0x3C194E        MySQL MISAM compressed data file Version 7
3947254       0x3C3AF6        MySQL MISAM compressed data file Version 1
3959838       0x3C6C1E        MySQL ISAM compressed data file Version 6
3960916       0x3C7054        MySQL ISAM compressed data file Version 2
3963214       0x3C794E        MySQL MISAM compressed data file Version 7
3998121       0x3D01A9        MySQL ISAM compressed data file Version 6
3998553       0x3D0359        MySQL ISAM compressed data file Version 6
4177707       0x3FBF2B        MySQL ISAM compressed data file Version 6
4189174       0x3FEBF6        MySQL MISAM index file Version 1
4200294       0x401766        MySQL MISAM compressed data file Version 7
4208486       0x403766        MySQL MISAM compressed data file Version 6
4224870       0x407766        MySQL MISAM compressed data file Version 6
4233454       0x4098EE        MySQL MISAM compressed data file Version 7
4235790       0x40A20E        MySQL MISAM index file Version 3
4364876       0x429A4C        MySQL MISAM index file Version 1
4397446       0x431986        MySQL MISAM index file Version 7
4422670       0x437C0E        MySQL MISAM compressed data file Version 7
4427222       0x438DD6        MySQL MISAM index file Version 3
4429038       0x4394EE        MySQL MISAM index file Version 3
4441926       0x43C746        MySQL MISAM compressed data file Version 7
4441998       0x43C78E        MySQL MISAM index file Version 3
4481409       0x446181        MySQL ISAM compressed data file Version 6
4490009       0x448319        MySQL ISAM compressed data file Version 6
4490265       0x448419        MySQL ISAM compressed data file Version 6
4490329       0x448459        MySQL ISAM compressed data file Version 6
4490457       0x4484D9        MySQL ISAM compressed data file Version 6
4490585       0x448559        MySQL ISAM compressed data file Version 6
4490649       0x448599        MySQL ISAM compressed data file Version 6
4490713       0x4485D9        MySQL ISAM compressed data file Version 6
4490777       0x448619        MySQL ISAM compressed data file Version 6
4490841       0x448659        MySQL ISAM compressed data file Version 6
4490905       0x448699        MySQL ISAM compressed data file Version 6
4490969       0x4486D9        MySQL ISAM compressed data file Version 6
4491033       0x448719        MySQL ISAM compressed data file Version 6
4491097       0x448759        MySQL ISAM compressed data file Version 6
4491161       0x448799        MySQL ISAM compressed data file Version 6
4491193       0x4487B9        MySQL ISAM compressed data file Version 6
4491257       0x4487F9        MySQL ISAM compressed data file Version 6
4491321       0x448839        MySQL ISAM compressed data file Version 6
4491369       0x448869        MySQL ISAM compressed data file Version 6
4491417       0x448899        MySQL ISAM compressed data file Version 6
4491481       0x4488D9        MySQL ISAM compressed data file Version 6
4491641       0x448979        MySQL ISAM compressed data file Version 6
4491705       0x4489B9        MySQL ISAM compressed data file Version 6
4491769       0x4489F9        MySQL ISAM compressed data file Version 6
4491833       0x448A39        MySQL ISAM compressed data file Version 6
4491897       0x448A79        MySQL ISAM compressed data file Version 6
4492025       0x448AF9        MySQL ISAM compressed data file Version 6
4492089       0x448B39        MySQL ISAM compressed data file Version 6
4492153       0x448B79        MySQL ISAM compressed data file Version 6
4492217       0x448BB9        MySQL ISAM compressed data file Version 6
4492281       0x448BF9        MySQL ISAM compressed data file Version 6
4492345       0x448C39        MySQL ISAM compressed data file Version 6
4492393       0x448C69        MySQL ISAM compressed data file Version 6
4492409       0x448C79        MySQL ISAM compressed data file Version 6
4492473       0x448CB9        MySQL ISAM compressed data file Version 6
4492537       0x448CF9        MySQL ISAM compressed data file Version 6
4492569       0x448D19        MySQL ISAM compressed data file Version 6
4492633       0x448D59        MySQL ISAM compressed data file Version 6
4492681       0x448D89        MySQL ISAM compressed data file Version 6
4492761       0x448DD9        MySQL ISAM compressed data file Version 6
4495070       0x4496DE        MySQL MISAM index file Version 3
4498457       0x44A419        MySQL ISAM compressed data file Version 6
4498521       0x44A459        MySQL ISAM compressed data file Version 6
4498649       0x44A4D9        MySQL ISAM compressed data file Version 6
4498777       0x44A559        MySQL ISAM compressed data file Version 6
4498841       0x44A599        MySQL ISAM compressed data file Version 6
4498905       0x44A5D9        MySQL ISAM compressed data file Version 6
4498969       0x44A619        MySQL ISAM compressed data file Version 6
4499033       0x44A659        MySQL ISAM compressed data file Version 6
4499097       0x44A699        MySQL ISAM compressed data file Version 6
4499161       0x44A6D9        MySQL ISAM compressed data file Version 6
4499225       0x44A719        MySQL ISAM compressed data file Version 6
4499289       0x44A759        MySQL ISAM compressed data file Version 6
4499353       0x44A799        MySQL ISAM compressed data file Version 6
4499385       0x44A7B9        MySQL ISAM compressed data file Version 6
4499449       0x44A7F9        MySQL ISAM compressed data file Version 6
4499513       0x44A839        MySQL ISAM compressed data file Version 6
4499561       0x44A869        MySQL ISAM compressed data file Version 6
4499609       0x44A899        MySQL ISAM compressed data file Version 6
4499673       0x44A8D9        MySQL ISAM compressed data file Version 6
4499833       0x44A979        MySQL ISAM compressed data file Version 6
4499897       0x44A9B9        MySQL ISAM compressed data file Version 6
4499961       0x44A9F9        MySQL ISAM compressed data file Version 6
4500025       0x44AA39        MySQL ISAM compressed data file Version 6
4500089       0x44AA79        MySQL ISAM compressed data file Version 6
4500217       0x44AAF9        MySQL ISAM compressed data file Version 6
4500281       0x44AB39        MySQL ISAM compressed data file Version 6
4500345       0x44AB79        MySQL ISAM compressed data file Version 6
4500409       0x44ABB9        MySQL ISAM compressed data file Version 6
4500473       0x44ABF9        MySQL ISAM compressed data file Version 6
4500537       0x44AC39        MySQL ISAM compressed data file Version 6
4500585       0x44AC69        MySQL ISAM compressed data file Version 6
4500601       0x44AC79        MySQL ISAM compressed data file Version 6
4500665       0x44ACB9        MySQL ISAM compressed data file Version 6
4500729       0x44ACF9        MySQL ISAM compressed data file Version 6
4500761       0x44AD19        MySQL ISAM compressed data file Version 6
4500825       0x44AD59        MySQL ISAM compressed data file Version 6
4500873       0x44AD89        MySQL ISAM compressed data file Version 6
4500953       0x44ADD9        MySQL ISAM compressed data file Version 6
4503262       0x44B6DE        MySQL MISAM index file Version 3
4522510       0x45020E        MySQL MISAM index file Version 3
4530702       0x45220E        MySQL MISAM index file Version 3
4667585       0x4738C1        MySQL ISAM compressed data file Version 6
4667590       0x4738C6        MySQL ISAM compressed data file Version 6
4667606       0x4738D6        MySQL ISAM compressed data file Version 6
4696558       0x47A9EE        MySQL MISAM compressed data file Version 6
4717156       0x47FA64        Boot section Start 0x-2110081E End 0x0
4774174       0x48D91E        MySQL MISAM index file Version 2
4807350       0x495AB6        MySQL MISAM index file Version 3
4868510       0x4A499E        MySQL MISAM index file Version 4
4917954       0x4B0AC2        LZMA compressed data, properties: 0x7E, dictionary size: 0 bytes, uncompressed size: 64 bytes
4998550       0x4C4596        MySQL MISAM compressed data file Version 5
5015329       0x4C8721        MySQL ISAM compressed data file Version 6
5040166       0x4CE826        MySQL ISAM compressed data file Version 2
5051670       0x4D1516        MySQL MISAM index file Version 3
5051926       0x4D1616        MySQL MISAM index file Version 3
5077242       0x4D78FA        Boot section Start 0x-7F7F7F80 End 0xFF8080
5118353       0x4E1991        MySQL ISAM compressed data file Version 6
5126545       0x4E3991        MySQL ISAM compressed data file Version 6
5171449       0x4EE8F9        Boot section Start 0x-1 End 0xFFFFFF
5171913       0x4EEAC9        Boot section Start 0x-1 End 0xFFFFFF
5176976       0x4EFE90        Boot section Start 0x3C3C3C3C End 0x787838
5197755       0x4F4FBB        MySQL MISAM index file Version 3
5213937       0x4F8EF1        MySQL MISAM compressed data file Version 7
5237784       0x4FEC18        Copyright string: "Copyright 10/01/86 Shouei System Programmed by Masahiro."ACTOR".Yoshihara Yasuhide.Sakakura Pictured by Kenichi."RINA".Suzuki Ma"
5265874       0x5059D2        Intel x86 or x64 microcode, sig 0x00000001, pf_mask 0xe0f0b008, 1B1F-01-21, rev 0xf3f0000, size 2048
5266926       0x505DEE        MySQL MISAM index file Version 6
5274066       0x5079D2        Intel x86 or x64 microcode, sig 0x00000001, pf_mask 0xe0f0b008, 1B1F-01-21, rev 0xf3f0000, size 2048
5275118       0x507DEE        MySQL MISAM index file Version 6
5344689       0x518DB1        MySQL ISAM compressed data file Version 6
5374761       0x520329        MySQL ISAM compressed data file Version 6
5382112       0x521FE0        Boot section Start 0x-2020203 End 0x-2020203
5388944       0x523A90        Boot section Start 0x42424242 End 0x43424242
5397136       0x525A90        Boot section Start 0x42424242 End 0x43424242
5403435       0x52732B        MySQL ISAM compressed data file Version 6
5404665       0x5277F9        MySQL ISAM compressed data file Version 6
5414009       0x529C79        Boot section Start 0x7E7E7E77 End 0x73777E
5468241       0x537051        MySQL ISAM compressed data file Version 6
5469702       0x537606        MySQL MISAM index file Version 2
5546806       0x54A336        MySQL MISAM compressed data file Version 6
5634174       0x55F87E        MySQL MISAM index file Version 3
5634606       0x55FA2E        MySQL ISAM compressed data file Version 6
5635182       0x55FC6E        MySQL MISAM index file Version 3
5704618       0x570BAA        Intel x86 or x64 microcode, sig 0xf8000101, pf_mask 0x1010101, 19F9-01-09, rev 0x-8000000, size 16843009
5720865       0x574B21        MySQL ISAM compressed data file Version 6
5770022       0x580B26        MySQL MISAM compressed data file Version 3
5770342       0x580C66        MySQL MISAM compressed data file Version 3
5862926       0x59760E        MySQL MISAM compressed data file Version 1
5867320       0x598738        Intel x86 or x64 microcode, sig 0x00000304, pf_mask 0x80000000, 2020-08-10, size 16777474
5875512       0x59A738        Intel x86 or x64 microcode, sig 0x00000304, pf_mask 0x80000000, 2020-08-10, size 16777474
5907638       0x5A24B6        MySQL MISAM index file Version 3
5932122       0x5A845A        Boot section Start 0x3C000000 End 0xFF7E
5934202       0x5A8C7A        Boot section Start 0x1F3F3F7F End 0x3F1F
5935090       0x5A8FF2        Boot section Start 0x42424242 End 0x7E
5935098       0x5A8FFA        Boot section Start 0x0 End 0x0
5945850       0x5AB9FA        Boot section Start 0x-1 End 0xFFFF
5946938       0x5ABE3A        Boot section Start 0x3C000000 End 0xFF7E
5947018       0x5ABE8A        Boot section Start 0x-6C0B404 End 0x7B4F
5948850       0x5AC5B2        Boot section Start 0x42424242 End 0xF19007E
5948858       0x5AC5BA        Boot section Start 0x0 End 0x60000
5948994       0x5AC642        Boot section Start 0x42424242 End 0x7E
5949002       0x5AC64A        Boot section Start 0x0 End 0xFF06
5949194       0x5AC70A        Boot section Start 0x3000000 End 0xDF0F
5949602       0x5AC8A2        Boot section Start 0x42424242 End 0x7E
5949610       0x5AC8AA        Boot section Start 0x0 End 0x7F1F
5954666       0x5ADC6A        Boot section Start 0x41414141 End 0x2051
5955210       0x5ADE8A        Boot section Start 0x-6C0B404 End 0x7B4F
5957194       0x5AE64A        Boot section Start 0x3F1F1F0F End 0xE42C
5959666       0x5AEFF2        Boot section Start 0x42424242 End 0x7E
5959674       0x5AEFFA        Boot section Start 0x0 End 0x0
5963402       0x5AFE8A        Boot section Start 0x-6C0B404 End 0x7B4F
5991638       0x5B6CD6        MySQL ISAM index file Version 5
6040046       0x5C29EE        MySQL MISAM compressed data file Version 6
6060644       0x5C7A64        Boot section Start 0x-2110081E End 0x0
6147154       0x5DCC52        Boot section Start 0x-1F1F1F20 End 0x-FF1F20
6165726       0x5E14DE        MySQL MISAM compressed data file Version 7
6166158       0x5E168E        MySQL MISAM compressed data file Version 3
6173918       0x5E34DE        MySQL MISAM compressed data file Version 7
6174350       0x5E368E        MySQL MISAM compressed data file Version 3
6231216       0x5F14B0        MySQL ISAM compressed data file Version 6
6231713       0x5F16A1        MySQL ISAM compressed data file Version 6
6274373       0x5FBD45        MySQL ISAM compressed data file Version 2
6502846       0x6339BE        MySQL MISAM compressed data file Version 7
6590097       0x648E91        MySQL ISAM compressed data file Version 6
6604850       0x64C832        Boot section Start 0x-243C3D End 0x-240001
6648838       0x657406        MySQL MISAM compressed data file Version 7
6668622       0x65C14E        MySQL MISAM compressed data file Version 7
6726204       0x66A23C        Intel x86 or x64 microcode, sig 0x3f3f7f7f, pf_mask 0x10102, 2020-10-10, rev 0x40408080, size 1
6739470       0x66D60E        MySQL MISAM index file Version 3
6763726       0x6734CE        MySQL ISAM index file Version 5
6763742       0x6734DE        MySQL ISAM index file Version 5
6782514       0x677E32        MySQL ISAM compressed data file Version 6
6790526       0x679D7E        MySQL ISAM compressed data file Version 2
6838486       0x6858D6        MySQL MISAM compressed data file Version 7
6869326       0x68D14E        MySQL MISAM compressed data file Version 7
6905041       0x695CD1        MySQL ISAM compressed data file Version 6
6905750       0x695F96        MySQL ISAM index file Version 3
6931954       0x69C5F2        Boot section Start 0x7C7C7C7C End 0x-FF8384
6932162       0x69C6C2        Boot section Start 0x-64646465 End 0x1B1B
6932832       0x69C960        Boot section Start 0x7C7C7C7C End 0x40407C7C Load-by-Bootrom
6986206       0x6A99DE        MySQL MISAM compressed data file Version 1
7013812       0x6B05B4        MySQL ISAM compressed data file Version 6
7022491       0x6B279B        MySQL ISAM compressed data file Version 2
7023659       0x6B2C2B        MySQL ISAM compressed data file Version 2
7069254       0x6BDE46        MySQL MISAM index file Version 3
7120193       0x6CA541        MySQL ISAM compressed data file Version 6
7120418       0x6CA622        MySQL ISAM compressed data file Version 6
7178049       0x6D8741        MySQL ISAM compressed data file Version 6
7178338       0x6D8862        MySQL ISAM compressed data file Version 6
7196930       0x6DD102        MySQL ISAM compressed data file Version 6
7199954       0x6DDCD2        MySQL ISAM compressed data file Version 6
7227777       0x6E4981        MySQL ISAM compressed data file Version 6
7227906       0x6E4A02        MySQL ISAM compressed data file Version 6
7961594       0x797BFA        Boot section Start 0x-60410308 End 0x878F
7971326       0x79A1FE        MySQL MISAM index file Version 7
7972078       0x79A4EE        MySQL MISAM index file Version 7
8004254       0x7A229E        MySQL MISAM compressed data file Version 8
8004340       0x7A22F4        Boot section Start 0x7E7E7E7E End 0x0
8084474       0x7B5BFA        Boot section Start 0x-60410308 End 0x878F
8108489       0x7BB9C9        MySQL ISAM compressed data file Version 6
8165833       0x7C99C9        MySQL ISAM compressed data file Version 6
8551245       0x827B4D        Copyright string: "Copyright (C) 1985  -  Version 4.01f"
8649549       0x83FB4D        Copyright string: "Copyright (C) 1985  -  Version 4.01f"
8795798       0x863696        MySQL MISAM index file Version 1
8819072       0x869180        MySQL ISAM compressed data file Version 6
8846135       0x86FB37        Intel x86 or x64 microcode, sig 0xff7f3f0f, pf_mask 0xfcfcfc00, 1E00-03-19, size 65760
9009997       0x897B4D        Copyright string: "Copyright (C) 1985  -  Version 4.01f"
9155185       0x8BB271        MySQL ISAM compressed data file Version 6
9155425       0x8BB361        MySQL ISAM compressed data file Version 6
9155921       0x8BB551        MySQL ISAM compressed data file Version 6
9162414       0x8BCEAE        MySQL MISAM index file Version 3
9363360       0x8EDFA0        MySQL ISAM compressed data file Version 6
9369320       0x8EF6E8        Boot section Start 0x0 End 0x2000
9377438       0x8F169E        MySQL MISAM index file Version 7
9460094       0x90597E        MySQL MISAM index file Version 3
9462735       0x9063CF        Intel x86 or x64 microcode, sig 0xf0f07868, pf_mask 0x3070400, 1B00-02-10, rev 0x402000, size 192
9478051       0x909FA3        Intel x86 or x64 microcode, sig 0x9e0fc703, pf_mask 0x9fbfffff, 1F0F-01-18, rev 0x7fffff07, size 2048
9596094       0x926CBE        MySQL MISAM index file Version 3
9606574       0x9295AE        MySQL MISAM index file Version 7
9705258       0x94172A        MySQL ISAM compressed data file Version 6
11026737      0xA84131        MySQL ISAM compressed data file Version 6
11027507      0xA84433        MySQL ISAM compressed data file Version 6
11028385      0xA847A1        MySQL ISAM compressed data file Version 6
11121008      0xA9B170        Boot section Start 0x-3030304 End 0x80FC
11121504      0xA9B360        Boot section Start 0x-3030304 End 0x-3030304
11121508      0xA9B364        Boot section Start 0x-3030304 End 0x0
11126257      0xA9C5F1        MySQL ISAM compressed data file Version 6
11126771      0xA9C7F3        MySQL ISAM compressed data file Version 6
11151449      0xAA2859        MySQL ISAM compressed data file Version 6
11155545      0xAA3859        MySQL ISAM compressed data file Version 6
11186183      0xAAB007        Intel x86 or x64 microcode, sig 0x08181010, pf_mask 0xff3f0003, 1F00-11-11, size 16777254
11259022      0xABCC8E        MySQL MISAM compressed data file Version 7
11262854      0xABDB86        MySQL MISAM index file Version 3
11305214      0xAC80FE        MySQL MISAM index file Version 4
11314430      0xACA4FE        MySQL MISAM index file Version 4
11318526      0xACB4FE        MySQL MISAM index file Version 4
11319550      0xACB8FE        MySQL MISAM index file Version 4
11320574      0xACBCFE        MySQL MISAM index file Version 4
11321598      0xACC0FE        MySQL MISAM index file Version 4
11330814      0xACE4FE        MySQL MISAM index file Version 4
11333886      0xACF0FE        MySQL MISAM index file Version 4
11346174      0xAD20FE        MySQL MISAM index file Version 4
11350270      0xAD30FE        MySQL MISAM index file Version 4
11352318      0xAD38FE        MySQL MISAM index file Version 4
11365038      0xAD6AAE        MySQL MISAM index file Version 3
11372980      0xAD89B4        MySQL MISAM index file Version 9
11373875      0xAD8D33        MySQL MISAM index file Version 2
11412398      0xAE23AE        MySQL MISAM index file Version 1
11443166      0xAE9BDE        MySQL MISAM index file Version 11
11487383      0xAF4897        MySQL ISAM index file Version 5
11521552      0xAFCE10        Boot section Start 0x-2020203 End 0x-2020203
11553088      0xB04940        Boot section Start 0x181818 End 0x18181800
11567010      0xB07FA2        Boot section Start 0x3C3C3C3C End 0x38
11578958      0xB0AE4E        MySQL ISAM index file Version 1
11606438      0xB119A6        MySQL MISAM compressed data file Version 7
11706354      0xB29FF2        Boot section Start 0x0 End 0x0
11713426      0xB2BB92        Boot section Start 0x42424242 End 0x7E
11713434      0xB2BB9A        Boot section Start 0x0 End 0x0
11713522      0xB2BBF2        Boot section Start 0x42424242 End 0x7E
11713530      0xB2BBFA        Boot section Start 0x0 End 0x0
11713802      0xB2BD0A        Boot section Start 0x-38FD End 0xFFFF
11743218      0xB32FF2        Boot section Start 0x42424242 End 0x7E
11743226      0xB32FFA        Boot section Start 0x0 End 0x0
11749362      0xB347F2        Boot section Start 0x42424242 End 0x7E
11749370      0xB347FA        Boot section Start 0x0 End 0x0
11753458      0xB357F2        Boot section Start 0x42424242 End 0x7E
11753466      0xB357FA        Boot section Start 0x0 End 0x0
11755002      0xB35DFA        Boot section Start 0x-1 End 0xFFFF
11755506      0xB35FF2        Boot section Start 0x42424242 End 0x7E
11755514      0xB35FFA        Boot section Start 0x0 End 0x0
11759602      0xB36FF2        Boot section Start 0x42424242 End 0x7E
11759610      0xB36FFA        Boot section Start 0x0 End 0x0
11761462      0xB37736        MySQL MISAM index file Version 3
11762822      0xB37C86        MySQL MISAM index file Version 3
11772222      0xB3A13E        MySQL MISAM index file Version 1
11782154      0xB3C80A        Boot section Start 0x0 End 0x701
11878361      0xB53FD9        MySQL MISAM index file Version 3
11881718      0xB54CF6        MySQL MISAM index file Version 3
11886105      0xB55E19        MySQL ISAM compressed data file Version 6
11890649      0xB56FD9        MySQL ISAM compressed data file Version 6
11893451      0xB57ACB        Boot section Start 0xFF00FF End 0x-FFFF01
11894289      0xB57E11        MySQL ISAM compressed data file Version 6
11898150      0xB58D26        MySQL MISAM index file Version 1
11898841      0xB58FD9        MySQL ISAM compressed data file Version 6
12002564      0xB72504        MySQL ISAM compressed data file Version 6
12017931      0xB7610B        Boot section Start 0x0 End 0x-301FF00
12021730      0xB76FE2        Boot section Start 0x42424242 End 0x7E
12021738      0xB76FEA        Boot section Start 0x0 End 0x0
12039666      0xB7B5F2        Boot section Start 0x42424242 End 0x7E
12039674      0xB7B5FA        Boot section Start 0x0 End 0x0
12042210      0xB7BFE2        Boot section Start 0x42424242 End 0x7E
12042218      0xB7BFEA        Boot section Start 0x0 End 0x0
12044274      0xB7C7F2        Boot section Start 0x42424242 End 0x7E
12044282      0xB7C7FA        Boot section Start 0x0 End 0x0
12054498      0xB7EFE2        Boot section Start 0x42424242 End 0x7E
12054506      0xB7EFEA        Boot section Start 0x0 End 0x0
12057586      0xB7FBF2        Boot section Start 0x42424242 End 0x7E
12057594      0xB7FBFA        Boot section Start 0x0 End 0x0
12062462      0xB80EFE        MySQL MISAM compressed data file Version 3
12063777      0xB81421        MySQL ISAM compressed data file Version 1
12063785      0xB81429        MySQL ISAM compressed data file Version 1
12119806      0xB8EEFE        MySQL MISAM compressed data file Version 3
12122254      0xB8F88E        MySQL ISAM compressed data file Version 6
12258062      0xBB0B0E        MySQL ISAM compressed data file Version 6
12268835      0xBB3523        MySQL ISAM compressed data file Version 6
12279217      0xBB5DB1        MySQL MISAM compressed data file Version 6
12389134      0xBD0B0E        MySQL ISAM compressed data file Version 6
12399907      0xBD3523        MySQL ISAM compressed data file Version 6
12410289      0xBD5DB1        MySQL MISAM compressed data file Version 6
12455678      0xBE0EFE        MySQL MISAM compressed data file Version 3
12467528      0xBE3D48        MySQL ISAM compressed data file Version 2
12513022      0xBEEEFE        MySQL MISAM compressed data file Version 3
12519822      0xBF098E        MySQL MISAM compressed data file Version 7
12576108      0xBFE56C        Intel x86 or x64 microcode, sig 0x80508060, pf_mask 0xffff7fff, 1F0B-02-05, rev 0x7faf7f9f, size 32768
12586750      0xC00EFE        MySQL MISAM compressed data file Version 3
12598600      0xC03D48        MySQL ISAM compressed data file Version 2
12644094      0xC0EEFE        MySQL MISAM compressed data file Version 3
12650894      0xC1098E        MySQL MISAM compressed data file Version 7
12707180      0xC1E56C        Intel x86 or x64 microcode, sig 0x80508060, pf_mask 0xffff7fff, 1F0B-02-05, rev 0x7faf7f9f, size 32768
12716454      0xC209A6        MySQL MISAM index file Version 5
12877290      0xC47DEA        MySQL ISAM compressed data file Version 2
12896179      0xC4C7B3        LZMA compressed data, properties: 0xC0, dictionary size: 0 bytes, uncompressed size: 128 bytes
12901150      0xC4DB1E        MySQL MISAM index file Version 3
13062622      0xC751DE        MySQL ISAM compressed data file Version 6
13273934      0xCA8B4E        MySQL ISAM compressed data file Version 6
13278898      0xCA9EB2        Boot section Start 0x42424242 End 0x7E
13278906      0xCA9EBA        Boot section Start 0x0 End 0x0
13310136      0xCB18B8        Intel x86 or x64 microcode, sig 0x03030303, pf_mask 0x3030303, 1F00-03-03, size 2048
13315954      0xCB2F72        Boot section Start 0x42424242 End 0x7E
13315962      0xCB2F7A        Boot section Start 0x0 End 0x0
13328102      0xCB5EE6        MySQL MISAM compressed data file Version 3
13332338      0xCB6F72        Boot section Start 0x0 End 0x0
13357558      0xCBD1F6        MySQL ISAM compressed data file Version 6
13370290      0xCC03B2        Boot section Start 0x42424242 End 0x7E
13370298      0xCC03BA        Boot section Start 0x0 End 0x0
13373298      0xCC0F72        Boot section Start 0x42424242 End 0x7E
13373306      0xCC0F7A        Boot section Start 0x0 End 0x0
13376794      0xCC1D1A        Boot section Start 0x63637F63 End 0xF763
13406130      0xCC8FB2        Boot section Start 0x0 End 0x0
13406162      0xCC8FD2        Boot section Start 0x0 End 0x0
13418418      0xCCBFB2        Boot section Start 0x42424242 End 0x7E
13418426      0xCCBFBA        Boot section Start 0x0 End 0x0
13428570      0xCCE75A        Boot section Start 0x28802104 End 0x100000
13459602      0xCD6092        Boot section Start 0x42424242 End 0x7E
13459610      0xCD609A        Boot section Start 0x0 End 0xF00F
13497426      0xCDF452        Boot section Start 0x42424242 End 0x7E
13497434      0xCDF45A        Boot section Start 0x0 End 0x0
13501362      0xCE03B2        Boot section Start 0x42424242 End 0x7E
13501370      0xCE03BA        Boot section Start 0x0 End 0x0
13504354      0xCE0F62        Boot section Start 0x42424242 End 0x7E
13504362      0xCE0F6A        Boot section Start 0x0 End 0x0
13505778      0xCE14F2        Boot section Start 0x42424242 End 0x7E
13507770      0xCE1CBA        Boot section Start 0x-40000000 End 0xBCD8
13546518      0xCEB416        MySQL MISAM compressed data file Version 7
13553586      0xCECFB2        Boot section Start 0x42424242 End 0xFE
13553594      0xCECFBA        Boot section Start 0x0 End 0x0
13581823      0xCF3DFF        Intel x86 or x64 microcode, sig 0x19190019, pf_mask 0x19191900, 1900-19-19, size 6
13594474      0xCF6F6A        Boot section Start 0x0 End 0x0
13598570      0xCF7F6A        Boot section Start 0x0 End 0x0
13610638      0xCFAE8E        MySQL MISAM index file Version 3
13673918      0xD0A5BE        MySQL MISAM index file Version 1
13703811      0xD11A83        MySQL ISAM compressed data file Version 6
13732649      0xD18B29        MySQL ISAM compressed data file Version 6
13754512      0xD1E090        MySQL ISAM compressed data file Version 6
13764091      0xD205FB        MySQL ISAM compressed data file Version 6
13768696      0xD217F8        MySQL ISAM compressed data file Version 6
13777585      0xD23AB1        MySQL ISAM compressed data file Version 6
13788698      0xD2661A        MySQL ISAM compressed data file Version 6
13835950      0xD31EAE        MySQL ISAM index file Version 3
13842158      0xD336EE        MySQL MISAM index file Version 3
13959227      0xD5003B        MySQL ISAM compressed data file Version 6
13972201      0xD532E9        MySQL ISAM compressed data file Version 6
14047433      0xD658C9        MySQL ISAM compressed data file Version 6
14072835      0xD6BC03        MySQL ISAM compressed data file Version 2
14094961      0xD71271        MySQL ISAM compressed data file Version 6
14102177      0xD72EA1        MySQL ISAM compressed data file Version 6
14166710      0xD82AB6        MySQL MISAM compressed data file Version 7
14169513      0xD835A9        MySQL ISAM compressed data file Version 6
14290022      0xDA0C66        MySQL ISAM compressed data file Version 2
14298464      0xDA2D60        MySQL ISAM compressed data file Version 2
14302338      0xDA3C82        MySQL ISAM compressed data file Version 4
14308857      0xDA55F9        MySQL ISAM compressed data file Version 6
14316456      0xDA73A8        MySQL ISAM compressed data file Version 6
14326049      0xDA9921        MySQL ISAM compressed data file Version 6
14337009      0xDAC3F1        MySQL ISAM compressed data file Version 6
14339278      0xDACCCE        MySQL ISAM index file Version 5
14339809      0xDACEE1        MySQL ISAM compressed data file Version 6
14339817      0xDACEE9        MySQL ISAM compressed data file Version 6
14344737      0xDAE221        MySQL ISAM compressed data file Version 6
14345062      0xDAE366        MySQL MISAM compressed data file Version 3
14347409      0xDAEC91        MySQL ISAM compressed data file Version 6
14347417      0xDAEC99        MySQL ISAM compressed data file Version 6
14354153      0xDB06E9        MySQL ISAM compressed data file Version 6
14399480      0xDBB7F8        MySQL ISAM compressed data file Version 6
14400090      0xDBBA5A        MySQL ISAM compressed data file Version 6
14400186      0xDBBABA        MySQL ISAM compressed data file Version 6
14416241      0xDBF971        Intel x86 or x64 microcode, sig 0x10000000, pf_mask 0x59e7e7da, 1963-03-04, rev 0x-69000000, size 2048
14422401      0xDC1181        MySQL ISAM compressed data file Version 6
14441591      0xDC5C77        MySQL MISAM index file Version 1
14650015      0xDF8A9F        MySQL ISAM index file Version 9
14827294      0xE23F1E        MySQL MISAM compressed data file Version 6
14843678      0xE27F1E        MySQL MISAM compressed data file Version 6
14846142      0xE288BE        MySQL MISAM compressed data file Version 7
15066618      0xE5E5FA        Boot section Start 0x-1 End 0xFFFF
15068234      0xE5EC4A        Boot section Start 0xFF00 End 0xFF00
15068490      0xE5ED4A        Boot section Start 0xFF00 End 0xFF00
15068538      0xE5ED7A        Boot section Start 0x4 End 0x0
15141946      0xE70C3A        MySQL ISAM compressed data file Version 6
15167034      0xE76E3A        MySQL ISAM compressed data file Version 2
15179686      0xE79FA6        MySQL MISAM compressed data file Version 1
15188966      0xE7C3E6        MySQL ISAM compressed data file Version 4
15200734      0xE7F1DE        MySQL MISAM index file Version 6
15233817      0xE87319        MySQL ISAM compressed data file Version 6
15236353      0xE87D01        MySQL ISAM compressed data file Version 6
15237304      0xE880B8        Boot section Start 0x-7070708 End 0x-7070708
15237308      0xE880BC        Boot section Start 0x-7070708 End 0x0
15285075      0xE93B53        Intel x86 or x64 microcode, sig 0xf0006000, pf_mask 0x8464f47c, 1F07-04-03, rev 0x70f1300, size 128
15285203      0xE93BD3        Intel x86 or x64 microcode, sig 0xf0c00000, pf_mask 0xf0b89818, 1F07-04-03, rev 0xb0f0700, size 2048
15331443      0xE9F073        Intel x86 or x64 microcode, sig 0xf0006000, pf_mask 0x8464f47c, 1F07-04-03, rev 0x70f1300, size 128
15331571      0xE9F0F3        Intel x86 or x64 microcode, sig 0xf0c00000, pf_mask 0xf0b89818, 1F07-04-03, rev 0xb0f0700, size 2048
15397345      0xEAF1E1        MySQL ISAM compressed data file Version 6
15428178      0xEB6A52        MySQL ISAM compressed data file Version 6
15431810      0xEB7882        Boot section Start 0x0 End 0x3F0000
15433490      0xEB7F12        Boot section Start 0x0 End 0xFC0000
15439457      0xEB9661        MySQL ISAM compressed data file Version 6
15444274      0xEBA932        Boot section Start 0x0 End 0x80000
15452462      0xEBC92E        MySQL ISAM index file Version 5
15454098      0xEBCF92        Boot section Start 0x0 End 0x0
15480478      0xEC369E        MySQL MISAM compressed data file Version 7
15491588      0xEC6204        Boot section Start 0x3E3E3E3E End 0xFF00
15622384      0xEE60F0        MySQL ISAM compressed data file Version 6
15623912      0xEE66E8        MySQL ISAM compressed data file Version 6
15624282      0xEE685A        MySQL ISAM compressed data file Version 6
15665948      0xEF0B1C        MySQL ISAM compressed data file Version 6
15665974      0xEF0B36        MySQL ISAM compressed data file Version 6
15665990      0xEF0B46        MySQL ISAM compressed data file Version 6
15740088      0xF02CB8        MySQL ISAM compressed data file Version 6
15740291      0xF02D83        MySQL ISAM compressed data file Version 6
15740299      0xF02D8B        MySQL ISAM compressed data file Version 6
16066552      0xF527F8        Boot section Start 0x0 End 0x1C1C1818
16154312      0xF67EC8        MySQL ISAM compressed data file Version 2
16158553      0xF68F59        LZMA compressed data, properties: 0xC0, dictionary size: 0 bytes, uncompressed size: 192 bytes
16192574      0xF7143E        MySQL MISAM compressed data file Version 7
16200734      0xF7341E        MySQL MISAM index file Version 3
16228016      0xF79EB0        MySQL ISAM compressed data file Version 4
16235398      0xF7BB86        MySQL ISAM compressed data file Version 6
16236186      0xF7BE9A        MySQL ISAM compressed data file Version 6
16239494      0xF7CB86        MySQL ISAM compressed data file Version 6
16240282      0xF7CE9A        MySQL ISAM compressed data file Version 6
16365806      0xF9B8EE        MySQL MISAM index file Version 3
16402791      0xFA4967        Intel x86 or x64 microcode, sig 0xf46e3911, pf_mask 0x1010020, 1900-15-15, size 6
16405190      0xFA52C6        MySQL MISAM compressed data file Version 3
16451370      0xFB072A        Boot section Start 0x-1 End 0x7E00FFFF
16533697      0xFC48C1        MySQL ISAM compressed data file Version 6
16667406      0xFE530E        MySQL MISAM compressed data file Version 7
16698154      0xFECB2A        Boot section Start 0x-33330310 End 0xE0C4
16713146      0xFF05BA        Boot section Start 0x1010101 End 0x101
16723118      0xFF2CAE        MySQL ISAM index file Version 5
16754320      0xFFA690        Boot section Start 0x3C3C3C3C End 0x3C3C303C
16840796      0x100F85C       Boot section Start 0x43434343 End 0x43434343
16840800      0x100F860       Boot section Start 0x43434343 End 0x0
18239872      0x1165180       MySQL MISAM index file Version 3
18260398      0x116A1AE       Boot section Start 0x300 End 0x0
18263269      0x116ACE5       MySQL ISAM compressed data file Version 6
18287877      0x1170D05       Boot section Start 0x42424242 End 0x42
18287881      0x1170D09       Boot section Start 0x42 End 0x0
18287885      0x1170D0D       Boot section Start 0x0 End 0x0
18413931      0x118F96B       MySQL ISAM compressed data file Version 6
18686450      0x11D21F2       MySQL ISAM compressed data file Version 9
18916787      0x120A5B3       MySQL MISAM compressed data file Version 3
18994583      0x121D597       Boot section Start 0x42424242 End 0x3043
18994853      0x121D6A5       Boot section Start 0x2024242 End 0x6160
18994857      0x121D6A9       Boot section Start 0x6160 End 0x0
19660818      0x12C0012       Copyright string: "copyright Tue.24.Jun.1986 Shouei system / Pic. by K.Suzuki M.Higa / Prg. by M.Yoshihara Y.Kishimoto Y.Sakakura / BGM by M.Hara /"
19686830      0x12C65AE       Certificate in DER format (x509 v3), header length: 4, sequence length: 12418
19714820      0x12CD304       Boot section Start 0x0 End 0x0
19812999      0x12E5287       Copyright string: "copyright 1989  acclaim"
20754403      0x13CAFE3       MySQL MISAM compressed data file Version 7
22839312      0x15C8010       Copyright string: "Copyright 25/Sep/85 by Bear's Programmed by Bear's Ver1.0 Y.Sakakura  Y.Suzuki  A.Abe   T.Katoh   "
23897152      0x16CA440       Boot section Start 0x5F514F End 0x626160
23919453      0x16CFB5D       Copyright string: "Copyright (C) 1985  -  Version 4.01f"
24162577      0x170B111       Boot section Start 0x403F End 0x64000000
24162641      0x170B151       Boot section Start 0x1403F End 0x64000000
24164753      0x170B991       Boot section Start 0x403F0000 End 0x403F
24247117      0x171FB4D       Copyright string: "Copyright (C) 1985  -  Version 4.01f"
24410957      0x1747B4D       Copyright string: "Copyright (C) 1985  -  Version 4.01f"
25464002      0x1848CC2       MySQL ISAM compressed data file Version 2
25469301      0x184A175       MySQL ISAM compressed data file Version 6
25469493      0x184A235       MySQL ISAM compressed data file Version 6
25483943      0x184DAA7       MySQL ISAM compressed data file Version 6
26346605      0x192046D       Boot section Start 0x0 End 0x205A5800
26403724      0x192E38C       Boot section Start 0x0 End 0x0
26404681      0x192E749       Boot section Start 0x0 End 0x0
26712747      0x1979AAB       Intel x86 or x64 microcode, sig 0x00000300, pf_mask 0x01, 2000-01-03, rev 0x21000000, size 2048
26750195      0x1982CF3       Boot section Start 0x42424242 End 0x19434242
28468388      0x1B264A4       Certificate in DER format (x509 v3), header length: 4, sequence length: 12418
28709588      0x1B612D4       Boot section Start 0x5F5E3D2F End 0x2A002A00
28709648      0x1B61310       Boot section Start 0x3D2F3C42 End 0x5F5E004F
28709652      0x1B61314       Boot section Start 0x5F5E004F End 0x0
28710419      0x1B61613       Boot section Start 0x3D2F3C42 End 0x5F5E004F
30324542      0x1CEB73E       MySQL ISAM compressed data file Version 11
30324667      0x1CEB7BB       MySQL MISAM index file Version 10
30325914      0x1CEBC9A       MySQL MISAM index file Version 6
30816497      0x1D638F1       MySQL ISAM compressed data file Version 3
31052869      0x1D9D445       MySQL MISAM index file Version 2
31222287      0x1DC6A0F       MySQL ISAM compressed data file Version 6
31222357      0x1DC6A55       MySQL ISAM compressed data file Version 6
31614810      0x1E2675A       MySQL ISAM compressed data file Version 7
31983350      0x1E806F6       MySQL MISAM index file Version 3
32109142      0x1E9F256       MySQL MISAM compressed data file Version 7
32245236      0x1EC05F4       MySQL ISAM compressed data file Version 6
32251044      0x1EC1CA4       MySQL ISAM compressed data file Version 6
32256466      0x1EC31D2       MySQL ISAM compressed data file Version 6
32323562      0x1ED37EA       MySQL ISAM compressed data file Version 6
32460764      0x1EF4FDC       Boot section Start 0x0 End 0x0
32518446      0x1F0312E       MySQL MISAM index file Version 3
32562710      0x1F0DE16       MySQL ISAM compressed data file Version 8
32588918      0x1F14476       MySQL MISAM index file Version 1
32603485      0x1F17D5D       MySQL ISAM compressed data file Version 3
32616854      0x1F1B196       MySQL MISAM compressed data file Version 7
32635979      0x1F1FC4B       Boot section Start 0x0 End 0xFF0000
32879262      0x1F5B29E       MySQL ISAM compressed data file Version 6
33127632      0x1F97CD0       MySQL ISAM compressed data file Version 6
33134582      0x1F997F6       MySQL ISAM compressed data file Version 6
33267539      0x1FB9F53       End of Zip archive, footer length: 22
33305246      0x1FC329E       MySQL MISAM index file Version 3
33386454      0x1FD6FD6       MySQL MISAM compressed data file Version 7
PostPosted: July 13th, 2019, 19:02
There is a list of 620 games at offset 0x878A3D. Wouldn't this imply that the preceding code/data must constitute a menu system and perhaps a 6502 emulator? I would think that the game ROMs would be located after the games list.
PostPosted: July 13th, 2019, 20:16
yes I saw the list, I also have been parsing the rest of the dump, Results incomplete as yet.
