Post new topic Reply to topic  [ 105 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: Samsung RAID LIF 128GB SSD, any adaptor for it?????
PostPosted: July 18th, 2019, 7:25
Hello!
Help me please!
I try to connect to one of two mmcre28gqdxp disks directly through an adapter.
Connect not soldered and through pins.
Tester checked everything, OK.
The scheme is also hooked up everything correctly, power +3.3 is served.
The disk does not see any programs.
Where could there be a problem?
Thank you!
PostPosted: December 9th, 2019, 20:55
I have the same case here. Recently the old SONY VAIO laptop died and the SSD is a 256GB Samsung RAID LIF drive just like pictures showed here. Looks like there was a solution to the problem. Could someone help me out? I bought the LIF to SATA adaptor online with a white ribbon cable, but it won't fit the LIF connector on the drive. Thanks.
PostPosted: March 3rd, 2020, 6:46
imaarouf wrote:
Thank you, can you guide me with the pinout of the connector
Can you upload detailed photos of both sides of your PCB?
What are the markings on the flash controller?
In which machine (model number of Apple, Sony, etc) was this SSD installed? Sometimes the service manual will have the pinout.
AISI, the PCB is powered from +3.3V according to the information on the label. There are two SSDs on the board, one on each side. Each SSD has its own SATA Tx/Rx differential pairs.
The photo you have provided has a 5V TVS diode across the 3.3V input. Using the markings on the diode as a reference, I have identified the +3.3V and ground points on the board. Please confirm this for yourself, as serious damage will result if I've got it wrong.
SD05-7, Diodes Inc, marking ZA, 5V, 350W, UNI-DIRECTIONAL SURFACE MOUNT TVS:
http://www.diodes.com/datasheets/ds31594.pdf
The SATA data pairs should correspond to the following pinout, either directly or reversed:
http://pinoutsguide.com/HD/serialATA_pinout.shtml
Hi, You wrote well about this problem, could you help me with a similar one here? https://forum.hddguru.com/viewtopic.php?f=1&t=39563
PostPosted: July 1st, 2021, 12:30
i would like to expand my vaio`s svz1311 ssd drive from 128 Gb (it is traditional Samsung with LIF 29-pin connector) -> 512 Gb m2.sata SSD drive
i know it is possible, only several wires requred to be soldered
pls, help to find proper scheme to connect m2.sata SSD drive to LIF 29-pin connector on Samsung MZRPA128 ssd
PostPosted: March 5th, 2022, 15:01
hello all
my vaio vpcz21m9e is still working, although bsod almost every day. The three botton arrow keys (left,down,right) dont work no more.
Still, i like the laptop.
i think i read all posts here, and i cant find a solution using parts we can buy nowadays, to replace the hdd. Am i right ??
i read that some of you had damaged boards, but working disks ??
anyone interested in selling a good hdd to this Vaio ?? (and keyboard flat ribbon ?? or full keyboard ?)
or any other sugestion that i am not seeing ?
Many thanks
Andrekis
Users browsing this forum: No registered users and 246 guests
