 Post subject: HP V232W 16GB DEAD
PostPosted: August 1st, 2019, 10:45
HP V232W 16GB DEAD
please help to check voltage
 Post subject: Re: HP V232W 16GB DEAD
PostPosted: August 1st, 2019, 10:54
It could just be the picture, but it looks a bit dirty to me. Specifically between the pins of the square controller chip.
Have you tried giving it a bath in isopropyl alcohol, using a brush to clean all the contacts, and then fully drying it?
You might find that will solve the issue.
PostPosted: August 1st, 2019, 11:23
You can start by checking R5 (2.2Ω Resistor). It's common for that resistor to blow if there is a power issue.
Blizzard Data Recovery
PostPosted: August 1st, 2019, 13:01
Yep, it looks a little scorched too.
PostPosted: August 1st, 2019, 13:10
Indeed, I bet the crud around the controller pins is flux.
PostPosted: August 1st, 2019, 14:58
Oh, I didn't zoom in before, but you are right. Now I see it looks like the perennial toast mark in the R where it burned up.
PostPosted: August 6th, 2019, 15:33
gps31 wrote:
HP V232W 16GB DEAD
Hi GPS ,
I would be eager to work on this NAND whatever the price you need data for ,I am always there for help
PostPosted: August 6th, 2019, 21:30
what is the controller number? I can make out last digits "98M-QN" but not the first letters and numbers. Also what NAND chip is it. Photo of other side?
@Amarbir.. nice formatting! ;-)
