 Post subject: Single disk drive - Possible to flip disk when 1 head fails?
PostPosted: August 14th, 2019, 11:24
For a drive with a single double sided disk with 2 heads, if one head fails but drive will still initialise ok, does anyone know if theoretically you'd be able to image half the drive with the working head, then flip the disk over and image the other side with that working head?
 Post subject: Re: Single disk drive - Possible to flip disk when 1 head fa
PostPosted: August 14th, 2019, 11:30
If you think about it turning the disk over will make it spin backwards. Get a piece of card and mark an arrow on it pointing the same way on both sides. Then turn the card over and you will see it would spin backwards.
PostPosted: August 14th, 2019, 13:33
Well,
That Would Be a Nice Experiment ,But it should not work cos the servo info will not match the sector that its trying to fetch ,Generally when a head fails it should be properly inspected so that we come to know why it failed ,If its crashed on platter recovery would be very hard ,Which Drive is it BTW
PostPosted: August 14th, 2019, 14:05
You can hear Satan calling this way, like it was with vinyl's backmasking :lol:
But no, it will not work, sorry.
odzyskiwanie danych
PostPosted: August 14th, 2019, 15:48
100% not working.
PostPosted: August 15th, 2019, 9:19
1tb 3.5" Hiatchi HDS721010DLE630. Damn, head replacement it is then.
PostPosted: August 26th, 2019, 7:01
Banned User
never thought of that.
PostPosted: August 26th, 2019, 7:44
could flip it, then image in reverse ;-)
PostPosted: August 26th, 2019, 7:49
with this description, it will not work.
The best way to get useful advice is to share the complete drive information, problem etc.
maybe someone can help you in right direction.
Data Recovery Pakistan
Users browsing this forum: No registered users and 184 guests
