Forum rules
 Post subject: how can i get the ATA module of Seagate ST3500418AS
PostPosted: August 16th, 2019, 4:38
Hi~guys.
i am writing a postgraduate thesis focused on seagate firmware and i have developed a F3 tool to reading sysfile of Seagate ST3500418AS .
i do not understand the relationship with sysfile and ATA module. :roll:
how can i get the ATA module of Seagate ST3500418AS ?
if anyone can help me ,thanks a lot.
File comment: my f3 tool
 Post subject: Re: how can i get the ATA module of Seagate ST3500418AS
PostPosted: August 16th, 2019, 12:09
ATA Module is In Older Classic Pre F3 Drives Not F3 Drives
PostPosted: August 17th, 2019, 7:56
In terminal at level '1' command 's'.
You must first enable DITS and get modules using DITS:0x144.
More info in 'F3 Serial Port Diagnostics' and 'F3 Diagnostic Functions Manual'.
PostPosted: August 19th, 2019, 2:53
thank you very much :o
PostPosted: August 19th, 2019, 2:56
thank you very much . i will give it a try
PostPosted: June 29th, 2020, 9:44
There is no info about DITS commands, only DETS....
Can you give me an example of DITS:0x144, please.
Users browsing this forum: No registered users and 6 guests
