 Post subject: Can I swap Seagate Boards?
PostPosted: September 9th, 2019, 14:04
I have 2 Seagate ST3000DM008 HDDs in 2 different computers one of my computers had a massive PSU failure which wiped out 2 HDDs in the PC resulting in a dead drive... meaning it will not spin up and I believe it wiped out the driver board on this drive nor will it spin up in my other PC so the drive is dead as dead can be. My question is can I swap the board form my good 3TB drive and recover the data from the bad drive before I send it in the be serviced?
 Post subject: Re: Can I swap Seagate Boards?
PostPosted: September 9th, 2019, 14:20
If the pub boards have the same number, then yes...but not without swapping ROM chip as well.
http://www.rescue-it.se
PostPosted: September 9th, 2019, 14:41
Would that be the 8 pin 25S81A? I fear if I swap that it would void my warranty Seagate says to do the data recovery before you send the drive in lol sounds like a catch 22 (gray area) do you have an idea if that will void the warranty?
PostPosted: September 9th, 2019, 16:15
Can you show us photos of the component side of each PCB? Most times there is an easy DIY fix.
TVS Diode FAQ:
PostPosted: September 10th, 2019, 1:21
As the damage to your drives is caused by a faulty power supply, Seagate should not replace them under warranty. You may be lucky that the disks are not examined, but a power failure is easy to detect.
The ROM chip can be read out without removing the chip, but it requires an external chip reader.
You can also follow fzabkars advice and try to get the drives working, but that will also void warranty.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 11th, 2019, 11:13
Your right@digisupport I found the typical power spike damage it has at least one shorted diode and one blown resistor and possibly another blown resistor.
I found a PCB on flee bay for $20USD from china might go that route and swap the ROM unless you guys can give me some resistor values I will shoot you guys some pictures like @fzabkar recommended I have a hot air rework station minus a microscope but I think I can manage to change it out.
Thanks for your help.
PostPosted: September 11th, 2019, 11:31
The resistor is usually a zero-ohm resistor. If so, you can replace it with a wire link, or just flow a blob of solder over it.
PostPosted: September 11th, 2019, 15:32
if the surge reached the pream, it might have got busted, which can lead to serious data damage if you start it with a donor board
So preamp damage must be ruled out first.
Users browsing this forum: No registered users and 80 guests
