 Post subject: Wanted donor for WD5000AZLX
PostPosted: September 21st, 2019, 6:04
I am looking for a heads donor for WD5000AZLX (WD5000AZLX-75K2TA0).
Do you know if any other model will be compatybile?
 Post subject: Re: Wanted donor for WD5000AZLX
PostPosted: September 21st, 2019, 7:05
Have not seen that model here yet,
But i would expect it to be a TresXLB or TRESXLB2 drive
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 21st, 2019, 7:45
TRESXLB2
PostPosted: September 21st, 2019, 8:06
In my fw base i have these under TresXLB2:
WD10EZEX-00WN4A0, WD10EZEX-08WN4A0, WD10EZEX-21WN4A0, WD10EZEX-60WN4A0, WD10EZEX-75WN4A0, WD1003FZEX-00K3CA0
PostPosted: September 21st, 2019, 10:32
Are you suggesting that I can use any of those you mentioned?
PostPosted: September 22nd, 2019, 1:56
Yes, as long as the preamp matches.
Also, ISTR that your drive has two heads with one of them switched off, while the ones digisupport suggests have both heads enabled so you should be fine.
PostPosted: September 22nd, 2019, 3:10
My HDD has 1 physical head.
In such a case, is the compliance of the seventh DCM mark sufficient for the preamplifier compatibility?
I guess the production date is also important.
PostPosted: September 23rd, 2019, 15:36
Blue (7200RPM, 16MB cache, SATA-600 interface, Advanced Format)
WD3200AZKX-xxD6NAx 320GB (1/1 [short-stroked])
WD5000AZKX-xxD6NAx 500GB (1/1)
Blue (7200RPM, 32MB cache, SATA-600 interface, Advanced Format)
WD5000AZLX-xxK4KAx/xxCL5Ax/xxK2TAx/xxJKKAx 500GB (1/1)
Blue (7200RPM, 64MB cache, SATA-600 interface, Advanced Format)
WD7500AZEX-xxRKKAx/xxZF5Ax/xxBN5Ax 750GB (1/2 [short-stroked])
WD10EZEX-xxRKKAx/xxZF5Ax/xxBN5Ax/xxKUWAx/xxMFCAx/xxWN4Ax 1TB (1/2)
PostPosted: October 11th, 2019, 5:09
I found such a model. Please tell me if this could be a donor.
WD10EZEX-08WN4A0
DCM: HANNKT2CHB
date: 24 may 2017
My patient:
WD5000AZLX-75K2TA0
DCM: HARNKT2AHB
date: 23 apr 2017
Users browsing this forum: Google [Bot] and 119 guests
