 Post subject: spyglass Rom writing on Unlock pcb ?!!
PostPosted: October 17th, 2019, 14:51
want to write rom from patient spyglass pcb. to a new unlock pcb ..... without soldering .
i use palmer in utility
so i read rom from patient rom chip via programmer (( mini pro programmer )). file is ok and size is 1024 . then i write this file on my unlock pcb with pc3k
the disk stop spinning . died :roll: . rom died i think and some thing wrong on writing
any suggestions here
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
 Post subject: Re: spyglass Rom writing on Unlock pcb ?!!
PostPosted: October 17th, 2019, 15:12
sorry i mean charger not spyglass
Tawfeek Mokhtar
PostPosted: October 17th, 2019, 16:00
Write ROM to unlocked pcb with your external programmer, I do that all the time.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: October 17th, 2019, 16:33
you mean unsolder the rom then write with programmer then solder ?
Tawfeek Mokhtar
PostPosted: October 17th, 2019, 18:06
yes or simply transfer the chip
PostPosted: October 19th, 2019, 4:24
that's the usual , but the pcb is very thin and sensitive and with soldering many times it will gone
Tawfeek Mokhtar
PostPosted: October 20th, 2019, 14:49
Did you select the right chip? IIRC, these are 1M Bit 1.8V devices.
See if you can read the programmed chip and compare with known good file.
If you can't read it on the PCB, remove it and compare the contents with the buffer for the known good IC.
http://www.datasaversllc.com
PostPosted: October 20th, 2019, 15:31
I can check the ROM for you, or you can use my ROM parsing tool.
http://www.hddoracle.com/download/file.php?id=7881
http://www.hddoracle.com/download/file.php?id=8246
PostPosted: October 21st, 2019, 1:14
I prefer external programmer to read and write ROM without removing from the PCB.
REVELPROG-IS and the right clips has done a perfect job the last couple of years
PostPosted: October 21st, 2019, 2:36
have a look here, https://drive.google.com/file/d/14QM1eQ ... sp=sharing
the upgrade ver. of the clip
Tip: use Adjustable Stand :wink:
PostPosted: October 21st, 2019, 4:03
+1 what i use, some premade and homebrew for WSON :)
PostPosted: October 21st, 2019, 10:09
Humm, looks good but i think the ready one looks more practical than yours,,, replay the video and see how much it resists the pressure ,,, very strong
I like the DIY ver. to test but prefer the good quality for daily usage.
Thx for that :wink:
Users browsing this forum: Google [Bot] and 72 guests
