 Post subject: Seagate ST2000LM007 Problem
PostPosted: November 6th, 2019, 10:52
Hi
So I have this drive that I cant read any LBAs of User area, I unlock firmware with MRT , and during backup sys files, suddenly mrt cant bakup anymore , and when power on/off I got this error on Terminal
LED:0x000000EE FAddr:0x0056D1F2
and can not access terminal anymore, any solution ?
 Post subject: Re: Seagate ST2000LM007 Problem
PostPosted: November 6th, 2019, 13:55
guys, its urgent, please give me some advice :roll:
PostPosted: November 7th, 2019, 0:26
siamak5561 wrote:
Hi
Try using virtual start
PostPosted: November 7th, 2019, 3:36
gps31 wrote:
siamak5561 wrote:
Hi
the problem is I dont have Virtuall3D loader.
PostPosted: November 7th, 2019, 9:14
Highly likely a media cache issue.
Before attempting FW tricks, backup 28, 35, 93 and 348 through terminal, or kiss data goodbye
Will recover data for food
PostPosted: November 7th, 2019, 14:43
So I get virtual start file , but sadly not solve probelm, So i contact MRT Support, and they told me in MRT 2.1.4.1 I can fix this issue, but mine is 2.1.3.1 :( now im looking for new way!
its rosewood and locked terminal.
PostPosted: November 11th, 2019, 13:49
Really no one have any experience with rosewood here?
PostPosted: November 14th, 2019, 1:31
i got same error when that drive come from other dr and that dr just cut head with some f3 rom software and write's manipulated (cut head) Rom to Hdd , So we don't know any thing without Original Rom
PostPosted: November 14th, 2019, 3:45
for my case rom just changed for getting unlocked
PostPosted: November 17th, 2019, 4:04
is it solved already ?
can check it remotely if interested ?
Data Recovery Pakistan
PostPosted: November 17th, 2019, 15:36
Could you elaborate?
Are you saying that you used a donor ROM to access an unlocked terminal in a patient drive?
PostPosted: November 27th, 2019, 13:12
No , I mean rom changed By MRT to unlock terminal.
PostPosted: October 20th, 2020, 4:15
Hi guys, Im still have this drive with no success.
Boot 0x80M
Rst 0x80MSrv DETCR init 0x0000
PrgF
This is Terminal
Any further Help is appreciated.
and if you need any more info just tell me.
PostPosted: October 20th, 2020, 5:53
please send a screenshot of mrt , I need to see wath recognize mrt.
PostPosted: October 20th, 2020, 12:10
Well,
Update Your Tool ,This is one advise i can give you
PostPosted: October 20th, 2020, 12:12
This is what you want ?
PostPosted: October 20th, 2020, 12:17
hi friend, identify your product with boot code in fist panel after identification power off and on and go in normal mode. After this stop task and go in terminal, check if you have acces t leve and post screenshot please
PostPosted: October 20th, 2020, 12:18
Amarbir[CDR-Labs] wrote:
Well,
Well I send this a friend with MRT 2.1.4.1 and and still not solve the problem. and yes I need to update!
PostPosted: October 20th, 2020, 12:20
okay I have this
what is next?
PostPosted: October 20th, 2020, 19:57
probably 1d2
Users browsing this forum: Google [Bot], huangmiaofang and 44 guests
