 Post subject: ST3500418AS Sim error 1002
PostPosted: November 11th, 2019, 13:53
Hi
I have this drive for recovery with SIM ERROR 1002 in treminal ? what is sim error ? I able to image head 1 but head 0 is very slow like 300KB/s , any solution?
any Useful Congen command for increase speed ?
 Post subject: Re: ST3500418AS Sim error 1002
PostPosted: November 12th, 2019, 13:38
this is terminal Log
Rst 0x10M
SIM Error 1002
(P) SATA Reset
SIM Error 1002
SIM Error 1002
SIM Error 1002 PASS
SIM Error 1002
SIM Error 1002WriteDCOInfo FAILED during Initialization
RW: Error processing Performance Parameter File: 203C PASS
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
InitiateMarkPendingReallocateRequest for disc_lba: 00003DDE
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
PostPosted: November 12th, 2019, 19:49
https://www.data-medics.com/forum/seagate-f3-terminal-command-set-t901.html
PostPosted: November 13th, 2019, 3:21
Okay I see this
SIM error 1002 = this message alerts us to some error with one or more defect list. Potentially P-list or NRG list can be bad.
the is no entry on NRG
and 2097 entry on plist
and all V1 V2 V4 V10 V100 shows defects without problem.
maybe head issue? because I image data on head 1 very well.
F3 7>X
Head 00 Resistance 019D
Head 01 Resistance 0188
PostPosted: November 13th, 2019, 15:26
Did you try the Congen commands?
PostPosted: November 13th, 2019, 15:43
Yes and none of them make any difference.
PostPosted: November 13th, 2019, 16:02
Did the congen edits survive a power cycle? If not, then you may need to edit the same parameters in sys file 93h, and then save the file.
Users browsing this forum: Google [Bot] and 52 guests
