 Post subject: 320 GB HGST HDD just spins without being detected.
PostPosted: November 13th, 2019, 11:26
Hey you all,
Z7K320-320
HTS723232A7A364
DOM : 20JUL13
F/W: A/ZB70W A/A
I can hear quick arm movement inside when I power up disk but after that just spinning.
As I understand disk can't read SA.
I did try two PCBs without any luck (did swap BIOS chip).
Can It be bad firmware in BIOS chip? And if so, is it possible to fix it via dump?
 Post subject: Re: 320 GB HGST HDD just spins without being detected.
PostPosted: November 14th, 2019, 11:15
These models are known to have bad heads with the symptoms you described. Head swap required but regularly see platter damaged on these models.
PostPosted: November 14th, 2019, 14:43
Thank you for reply. Moving on to the next donor drive project :)
Users browsing this forum: No registered users and 124 guests
