 Post subject: Identify DVR file system
PostPosted: November 13th, 2019, 4:47
Hi is there a way to Identify DVR file system on a reinitialized hard drive under windows?
and is there a place to download first few sectors of dvr hard drives ? i mean like this attachment WFS 4 that I used for recovery from damaged DVR hard drive
File comment: WFS 4
0-0.zip [163 Bytes]
Downloaded 604 times
 Post subject: Re: Identify DVR file system
PostPosted: November 13th, 2019, 15:23
You can upload your sector dumps here.
BTW, if you have access to the DVR, install a donor drive and allow the DVR to format it. Then you will see what sector 0 looks like. If you're lucky, it will be the only sector that has been "initialised", in which case it may be that the solution is as simple as patching its contents into your patient (or clone).
PostPosted: November 13th, 2019, 15:46
Unfortunately I dont have access to DVR , and its a situation that costumer neither known DVR model.
PostPosted: November 13th, 2019, 15:47
You mean sector from patient drive? its just normally initialize by disk management in windows.
PostPosted: November 13th, 2019, 15:59
Windows only initialises sector 0. If the client has then created partitions and formatted them, then that's a different story. Show us something at least.
PostPosted: November 14th, 2019, 4:29
Honestly I dont have any idea what client do to hard drive.
this is first 10000 sectors.
0-9999.zip [130.2 KiB]
Downloaded 535 times
PostPosted: November 14th, 2019, 8:25
No partitions defined in sector 0. Some MFT fragments further out on drive created 11/9/2019, can not find much else. Many zeros. Some sort of table structure, a FAT?
PostPosted: November 14th, 2019, 10:24
DVRs file system such as WFS or DHFS only stand in first sector? i'v seen some data on sector 20 & 24 for WFS but I dont know if they related to WFS or not.
PostPosted: November 14th, 2019, 10:32
And I ask again, anyone know a place to download first few sectors of variety DVRs file system? this is Mine I have, only 4 DVR :oops:
DVR Recovery.rar [1.35 KiB]
Downloaded 636 times
PostPosted: November 14th, 2019, 12:14
I'm not sure I even understand what you ask and I also don't understand the obsession with the first sector.
PostPosted: November 14th, 2019, 19:49
looks like its not only initialized
its also been formated @ Nov. 09, 2019 07:29:54 (5 days ago)
PostPosted: November 27th, 2019, 13:11
In some cases, if i know what file system is used by DVR and client format or reinitialized drive, so I put back first few sectors of file system and easily recover clips.
PostPosted: November 27th, 2019, 17:09
If only initialized, did you scan with a tool with broad file system support, like R-Studio, ReclaiMe, UFS Explorer etc.?
