 Post subject: ST1500LM006 Liquit Damage, Motor not spin
PostPosted: December 1st, 2019, 18:03
Terminal log
ActiveFW : 00FWVer : 0001DDR detected:32MBDW SIPC status: 00000081SR
and bussy.
Cannot get ROM.
I dont have donor PCB. Couldnt find it in my country .
I need help for repair PCB
Sexy Womans from your town
 Post subject: Re: ST1500LM006 Liquit Damage, Motor not spin
PostPosted: December 1st, 2019, 20:26
ISTM that, if you are getting output from the terminal, then there can't be much wrong with the PCB, if anything.
Normally you should see the preamp ID in your terminal output. Could it be that the preamp has been damaged?
What voltages do you measure at each of the 3 coils and the diode at the top left corner?
Do you get a different terminal output when the PCB is off the drive?
PostPosted: December 2nd, 2019, 13:25
Same terminal log if power on just pcb. I have posted above that log.
Could you please mark which point voltages would I measure.
Is it possible to check preamp with measure from connection points?
PostPosted: December 2nd, 2019, 15:07
http://www.google.com/search?q=coil+inductor+smt&tbs=isz:m,itp:photo&tbm=isch
http://www.google.com/search?q=smt+diode+Schottky&tbs=isz:m,itp:photo&tbm=isch
PostPosted: December 4th, 2019, 11:53
PostPosted: December 4th, 2019, 12:34
Liquid damage - anything can be damaged
My advise: get a donor pcb in another country, M9T are not hard to find.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: December 4th, 2019, 12:49
PCB good
Bad ROM.
FIPS or CS ROM
Read ROM on progromator and show here.
PostPosted: December 4th, 2019, 13:49
As already stated, those voltages look good.
    Vio = 1.78V
    Vcore = 0.96V
I have written a tool to parse your ROM:
http://www.hddoracle.com/viewtopic.php?f=22&t=1846
PostPosted: December 4th, 2019, 14:09
Tomset wrote:
PCB good
Bad ROM.
FIPS or CS ROM
Tomorrow . I will try to get rom with my unusual methods. If couldn't get ROM dump I would try to read with programmer. I would write last situation in this topic
PostPosted: December 4th, 2019, 14:10
    Vio = 1.78V
    Vcore = 0.96V
Thanks bro
PostPosted: December 4th, 2019, 15:04
99% of the time, I find that there is absolutely no damage because of the spill and the issue is that the system was bounced around while the drive was still spinning, resulting in the heads getting stuck.
PostPosted: December 5th, 2019, 6:28
Not any moving, any sound. totally silence
PostPosted: December 5th, 2019, 6:44
Tomset wrote:
PCB good
Bad ROM.
FIPS or CS ROM
st1500LM006.rar [836.15 KiB]
Downloaded 1195 times
PostPosted: December 5th, 2019, 7:29
ROM too good
Из файла................................ : C:\!Profiles\Samsung\st1500LM006\512ROM.bin
Информация о дампе
Размер дампа............................ : 524288 байт
Контрольная сумма микропрограммы........ : Ok
Смещение FIPS........................... : 0x00001000
Размер FIPS............................. : 4096 байт
Контрольная сумма FIPS.................. : Ok
Тип микропрограммы...................... : Main Code
Оригинальное название................... : 2BC72AM.131
Platform Id............................. : 0x1F
Карта головок........................... : 0, 1, 2, 3, 4, 5
Тест завершен
Isolate only the Preamp. Leaving the motor contacts.
Does the motor spin?
PostPosted: December 5th, 2019, 8:05
On the M9T I have seen, isolated head connector or damaged preamp will prevent motor start.
With error: >>>Invalid PA VID
*PA VID=xxxx PN=xxxx Rev=xxxx Invalid Preamp
Have seen faulty PCB stopping @ ActiveFW : 00 FWVer : 0001DDR detected:32MB
I would still look for a tested and working PCB
PostPosted: December 5th, 2019, 9:11
I found donor PCB.
Case solved. Drive working properly.
Thanks for advices.
PostPosted: December 5th, 2019, 15:00
My tool also finds nothing wrong with your ROM.
Verifying Samsung SpinPoint ROM:  512ROM.bin
Checksum of Boot Block header = 0x63  - OK
Checksum of Boot Block (Actual/Expected) = 0x7283 / 0x7283  - OK
Searching for FIPS block (expected checksum = 0x0000) ...
Found FIPS text string at 0x001000
Checksum for 0x0400 byte FIPS block = 0xC4E6  - BAD
Checksum for 0x0800 byte FIPS block = 0x7335  - BAD
Checksum for 0x0C00 byte FIPS block = 0x3E92  - BAD
Checksum for 0x1000 byte FIPS block = 0x0000  - OK
Found FIPS text string at 0x00A6EA
Checksum for 0x0400 byte FIPS block = 0xED2C  - BAD
Checksum for 0x0800 byte FIPS block = 0x6E3E  - BAD
Checksum for 0x0C00 byte FIPS block = 0x516C  - BAD
Checksum for 0x1000 byte FIPS block = 0x72A9  - BAD
Found FIPS text string at 0x01C9E0
Checksum for 0x0400 byte FIPS block = 0xDBB2  - BAD
Checksum for 0x0800 byte FIPS block = 0x3763  - BAD
Checksum for 0x0C00 byte FIPS block = 0x07E2  - BAD
Checksum for 0x1000 byte FIPS block = 0x850A  - BAD
Found FIPS text string at 0x02FBFD
Checksum for 0x0400 byte FIPS block = 0xADC5  - BAD
Checksum for 0x0800 byte FIPS block = 0x017E  - BAD
Checksum for 0x0C00 byte FIPS block = 0x7003  - BAD
Checksum for 0x1000 byte FIPS block = 0x834B  - BAD
Possible 0x1000 byte FIPS block at address 0x001000
Searching for FLASHTBL ...
Found FLASHTBL text string at 0x002024
Parsing FLASHTBL at 0x002000 ...
ID Byt1 Byt3    Size   ROM address range   RAMaddrs  Cksm (Exp/Act)
00  00   FF         0                             0            N/A
01  40   FF         0                         14D00            N/A
02  02   FF       300     2000 - 22FF      FFF02000  00 98   - BAD (Note 2)
03  08   FF      1EC8     2300 - 41C7      FFF02300  31 31   - OK
04  00   FF     14CD8     41D0 - 18EA7            0  33 33   - OK
05  40   FF      2FAC    18EB0 - 1BE5B        14D00  C2 C2   - OK
06  00   FF       B74    1BE64 - 1C9D7        80000  0F 0F   - OK
07  00   FF       37C    1C9E0 - 1CD5B        85C00  E2 E2   - OK
08  00   FF       230    1CD64 - 1CF93        88000  C5 C5   - OK
09  80   FF     4D6F8    1CF9C - 6A693     10018000  13 13   - OK
0A  00   FF      6710    6A69C - 70DAB     900003C0  E3 E3   - OK
0B  08   FF         0                      FFF02300            N/A
Found FLASHTBL text string at 0x04CB1F
Inconsistent ID
Found FLASHTBL text string at 0x0545B3
Inconsistent ID
Searching for SERVOTBL ...
Found SERVOTBL text string at 0x071024
Parsing SERVOTBL at 0x071000 ...
00  02   FF        C0    71000 - 710BF     FFF71000  00 9C   - BAD (Note 2)
01  00   FF      CA64    710C4 - 7DB27            0  28 28   - OK
02  00   FF       F68    7DB30 - 7EA97        80000  80 80   - OK
Size            - size of module in ROM expressed in bytes
ROM address     - absolute address range of module in ROM
RAMaddrs        - load point of module in RAM
Cksm (Exp/Act)  - Expected Checksum / Actual Checksum
Note 1:  The address range of affected module may conflict with another module,
          in which case this is probably a false negative.
Note 2:  If this module is the FLASHTBL or SERVOTBL, then this is most likely
          a false negative.
Note 3:  This may or may not be a genuinely BAD module. Examine the checksum
          of the first half of the ROM. If 0x0000, then module is probably OK,
          otherwise it may or may not be bad. Also examine the "adjusted"
          checksum, if applicable.
Note 4:  The address range of the module is outside the limits of the ROM.
Calculating ROM checksums ...
Checksum for 0x000000 - 0x03FFFF = 0x02B5
Checksum for 0x040000 - 0x07FFFF = 0x064D
Checksum for entire ROM = 0x0902
Extents reported by FLASHTBL header = 0x000000 - 0x070FFF
Extents reported by SERVOTBL header = 0x071000 - 0x07FFFF
Checksum from 0 to end of SERVOTBL = 0x0902
Checksum (adjusted) from 0 to end of SERVOTBL = 0x0000
PostPosted: December 5th, 2019, 17:22
@fzabkar special thanks to your kindly helps. I have learned much things from your replies at this forum. Also I realized there could be PCB fault after you asked me some points voltages . I measured more points . I am still learning, but recognized something wrong on PCB. My lucky I could get a borrow donor PCB from a DR company.
I havent try your tool. I would try your tool later. But happy about your tool works
PostPosted: December 5th, 2019, 17:41
Here is a similar problem (with no resolution):
https://www.data-medics.com/forum/not-spinning-after-drop-st2000lm003-hn-m201rad-av2-t2018.html
Very strange ...
PostPosted: December 6th, 2019, 3:27
Says PCB problem. Donor PCB solved in 2nd page. Same issue
Users browsing this forum: No registered users and 31 guests
