 Post subject: ST2000LM007-1R8174 EB01 Problem
PostPosted: December 11th, 2019, 0:12
HDD: ST2000LM007
P/N: 1R8174-570
F/W: EB01 DOM: 24JAN2019
I m getting in Terminal
Boot 0x80M
TCC:001C
QB
Rst 0x80M
T:0x0003 0x00000000
FTU
TCC:001C:0021 EMCDataErr:00000018
PrgF
(P) SATA Reset
RAW OFF
 PASS
 Primary is latest! - 00000001
 RECOV Servo Op=0095 Resp=0005
DSC PASS
[MCMTW_DSW] Secondary - 00014FAF  LPCDisc=01 19EA59E9 0167
PrgF
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: Phy Ready without COMRESET, Status=50
CSpd= 3Gbps
FIS34
[BRO - 0002] 001BA1990A - 001BA1A863 Extents - 0002 Blk - 00001330 D - 000010C6
Starting LBA of RW Request=001BA1990A  Length=00000F5A
ProcessRWError -Read-   at LBA 001BA19B03  Sense Code=43110081
ProcessRC: 00000000,00000000
SkipLen: 00000000
ReadContinuous: 1BA19A93,00000312
CFD twk 5C->59
TotalEntries:01D0   XfrLen:0312
UnrecovSectorCount:01D0,01CF,0312
Retry error: 44030094
CFD twk 59->56
TotalEntries:0067   XfrLen:0312
UnrecovSectorCount:0067,0066,0312
it is running running running ........
How to solve this issue?
 Post subject: Re: ST2000LM007-1R8174 EB01 Problem
PostPosted: December 11th, 2019, 0:52
http://en.mrtlab.com/st-2-1-4-x-advance ... b01-unlock
VEXUS Data Recovery
PostPosted: December 12th, 2019, 15:26
If you have PC3K you can still patch this ROM on Janus, just changing one step.
Data Recovery Cape Town
PostPosted: December 13th, 2019, 6:40
No I have MRT 2.1.4.1 only.
Still can't solve the issue.
MRT Virtual Start - Not Solved
Edit HDD ID( Stop Reallocation) - Not Solved
F3 T> reached
at prompt no issue
can read all system files without error
but when try to image the hdd i m getting these
SkipLen: 00000000
CFD twk 5C->59
CFD twk 59->56
What to do for solving this issue?
waiting for advice
PostPosted: December 13th, 2019, 8:54
Terminal error is
Starting LBA of RW Request=00008E07F7 Length=000009A8
ProcessRWError -Read- at LBA 00008E0A05 Sense Code=43160080ProcessRC: 00000000,00000000SkipLen: 00000000ReadContinuous: 008E0993,00000338CFD twk 57->54TotalEntries:01ED XfrLen:0338UnrecovSectorCount:0002,01EC,014DRetry error: 44030094ReadContinuous: 008E0993,00000338CFD twk 54->51TotalEntries:0072 XfrLen:0338UnrecovSectorCount:0000,0000,0276Retry error: 44030094ReadContinuous: 008E0993,00000338CFD twk 51->48TotalEntries:0072 XfrLen:0338UnrecovSectorCount:0000,0000,0254Retry error: 44030094ReadContinuous: 008E0993,00000338TotalEntries:0072 XfrLen:0338UnrecovSectorCount:0000,0000,0254Retry error: 44030094ReadContinuous: 008E0993,00000338CFD twk 57->54TotalEntries:01ED XfrLen:0338UnrecovSectorCount:0002,01EC,00DBRetry error: 44030094ReadContinuous: 008E0993,00000338CFD twk 54->51TotalEntries:0072 XfrLen:0338UnrecovSectorCount:0000,0000,0276Retry error: 44030094ReadContinuous: 008E0993,00000338CFD twk 51->48TotalEntries:0072 XfrLen:0338UnrecovSectorCount:0000,0000,0254Retry error: 44030094ReadContinuous: 008E0993,00000338TotalEntries:0072 XfrLen:0338UnrecovSectorCount:0000,0000,0254Retry error: 44030094ReadContinuous: 008E0993,00000338CFD twk 57->54TotalEntries:01ED XfrLen:0338UnrecovSectorCount:0002,01EC,00DBRetry error: 44030094ReadContinuous: 008E0993,00000338CFD twk 54->51TotalEntries:0072 XfrLen:0338UnrecovSectorCount:0000,0000,0276Retry error: 44030094ReadContinuous: 008E0993,00000338CFD twk 51->48TotalEntries:0072 XfrLen:0338UnrecovSectorCount:0000,0000,0254Retry error: 44030094ReadContinuous: 008E0993,00000338TotalEntries:0072 XfrLen:0338UnrecovSectorCount:0000,0000,0254Retry error: 44030094ReadContinuous: 008E0993,00000338CFD twk 57->54TotalEntries:01ED
Struck with this error?
PostPosted: December 18th, 2019, 11:34
Well,
GPS how are you change the heads and then disable background processes might be that helps .
Users browsing this forum: Google [Bot] and 45 guests
