Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: HD103SJ dead
PostPosted: December 17th, 2019, 6:49
Your rom has FIPS deleted completely.
Here's a rom dump with correct FIPS, try it.
rom.zip [172.87 KiB]
Downloaded 706 times
PostPosted: December 17th, 2019, 10:05
pepe: the drive starts spinning with your dump :) Terminal output is attached - what do you think?
I haven't connected it to SATA yet.
File comment: Terminal log with pepes rom dump
HD103SJ_pepeROM.log [5.8 KiB]
Downloaded 588 times
PostPosted: December 17th, 2019, 10:44
That log looks promising.
It should be able to give you its content, but the best would be imaging it without letting the OS mess with the file system.
You may try hooking it up to an OS but don't force it too much, turn it off if the system starts hanging.
Better connect it under a linux and try cloning it for example. Be extremely careful with linux coz you may erase the source drive if you copy in the wrong direction.
Cloning may take a long time and even longer if the drive has bad sectors. It would be better to image it using pc3k applying some fw patches if it has bads...
To be honest i would be happier if it was cloned by a specialist using appropriate tools, coz it is easy to screw it up, either by reversing the direction or not noticing if the drive starts dying more severly.
PostPosted: December 17th, 2019, 15:10
As a precaution, clean the HDA pads with a soft eraser.
Oxidisation on Samsung HD103SJ:
http://www.hddoracle.com/viewtopic.php?f=86&t=649&p=21622#p15950
Clone the drive with HDDSuperClone or ddrescue.
PostPosted: December 19th, 2019, 7:47
I tried starting linux from an USB boot stick, but the HD103SJ is not recognized by the BIOS (it hangs).
Then I disconnected the SATA cable, and connected it after the POST, just before linux started loading.
Linux tries to communicate with the drive, but without success - the HD103SJ is not shown. There are two cases:
a) within the first 2..3 minutes after power-up - while the terminal output takes place - the drive somehow responds (Linux_log.jpg)
b) if I delay the linux startup until the HD103SJ terminal output is finished, the drive does not respond in any way (Linux_log2.jpg)
I cleaned the HDA pads as they didn't look perfect.
The drive spins up very smoothly and doesn't make any unusual sounds. Can the heads or surface however be damaged, that it can't get ready?
File comment: Complete HD103SJ terminal log
20191219113117.log [7.08 KiB]
Downloaded 677 times
File comment: HDA pads before cleaning
File comment: Linux output after HD103SJ finished terminal output
File comment: Linux output while HD103SJ terminal output is running
PostPosted: December 19th, 2019, 12:20
">>Flag=00000C8B BadHd=0000 dFod=003E 0026 0029 0024 (t=8773 c=24)"
It seems to me that Hd 0 is bad, but I could be wrong.....
The SMART is not initialized so the drive is rejected by the BIOS and the OS.
PostPosted: December 19th, 2019, 13:57
Time for a specialist i think...
Users browsing this forum: No registered users and 53 guests
