 Post subject: WD10TMVW-11ZSMS4 Encrypted disk
PostPosted: January 4th, 2020, 11:43
WD10TMVW-11ZSMS4
Drive has 6 head. H3 bad
I have tried Head map in DE, All head transfering data properly with no bad sector.
But I recognised drive encrypted. Customer said never used password.
I could decrypt data. But there is scraching noises when image with decryption.
So my question, I am thinking about clone encrypted data to target and decrypt from target drive.
Is it posible to decrypt this data from target drive after clone ?
My target drive 3.5" WD10EARS
Sexy Womans from your town
 Post subject: Re: WD10TMVW-11ZSMS4 Encrypted disk
PostPosted: January 4th, 2020, 12:04
Ok.
Quick solved.
I closed H3 in RAM. Now everything ok.
I could image 5 Head ( without H3) nice and full speed.
PostPosted: January 4th, 2020, 12:05
use decryption by file (encryption module) instead of decryption from SA on runtime. maybe it will help.
Data Recovery Pakistan
PostPosted: January 4th, 2020, 12:06
I would try that later. I am imaging properly right now
PostPosted: January 4th, 2020, 12:43
Is it just me, or why wouldn’t you change heads if one head is scratching?
I guessing maybe that client is totally unwilling to pay for parts and headswap for better chances of full recovery and would be happy with partial recovery?
PostPosted: January 4th, 2020, 15:59
I gave cheap cost for partial recovery . Client accepted all risk and cheaper solution.
Imaging full speed no slow or bad sector till now. Its around 65% now. I guess, 5 head would give all data .
If she accept head swap at first , I would follow same steps. First image working head and head swap. This is my way.
PostPosted: January 4th, 2020, 17:19
5 working head imaged 100%
Lucky me and client
PostPosted: January 4th, 2020, 17:37
Good job.
Helios are always tricky
PostPosted: January 4th, 2020, 17:51
Fair enough, that’s what I figured.
PostPosted: January 6th, 2020, 5:30
If client chose a partial recovery, I would have cut the "scraching" head before any data extraction.
I never image working heads before a swap, but that is my way :)
Digitalsupport Data Recovery
https://digitalsupport.dk
