 Post subject: ST3200542AS locked terminal?
PostPosted: January 8th, 2020, 3:32
Hello, I can't have access through terminal to this drive. No matter what I do, with the board insulated from the disk there is not way to get the "F3>3" command line. The only way to have some output is with the board connected but it doesn't go past "rst 0x20m (p) sata reset".
Is this model terminal locked? Thanks a lot
 Post subject: Re: ST3200542AS locked terminal?
PostPosted: January 9th, 2020, 2:39
Maybe ST32000542AS? This disk has a terminal code on the platters. In the event of a SA malfunction, to get to the terminal, you need to shorten the reading channel on the PCB at the right time.
PostPosted: January 9th, 2020, 6:10
I've tried to look for those points with no luck, do you know where they are?
PostPosted: January 9th, 2020, 6:49
https://yadi.sk/d/BGCV8X8CbKWGQg
PostPosted: January 9th, 2020, 15:25
Tip: How to identify the Read Channel test points:
http://www.hddoracle.com/viewtopic.php?f=24&t=123
PostPosted: January 11th, 2020, 13:36
Thanks a lot
Users browsing this forum: Majestic-12 [Bot] and 43 guests
