 Post subject: Modifying firmware on HP SSD M700 using MPTool?
PostPosted: January 14th, 2020, 15:21
Here is what I am working with:
SMI 224x / 225x SSD Flash ID ATA reader v0.556a by Ochkin Vadim
OS: 10.0 build 10240
Drive: 1 (ATA)
Model: HP SSD M700 120GB
Fw: Q1107A1
From smart: [SMI2258XT] [Q1107A1 00]
Controller : SM2258
FlashID: 0xec, 0x3a, 0x94,0x43,0xa4,0xca, 0x0,0x0 - Samsung 14nm MLC 16k 128Gb / CE 128Gb / die
Channel: 2
CE: 4
TotDie: 8
Plane: 2
Die / Ce: 1
Ch map: 0x03
CE map: 0x0F
Inter. : 4
First Fblock: 2
Total Fblock: 1763
Total Hblock: 1789
Fblock Per Ce: 1763
Fblock Per Die: 1763
Original Spare Block Count: 129
Vendor Marked Bad Block: 0
Bad Block From Pretest: 18
Looking to dump the firmware, modify the serial number and/or model number, and reflash.
Tried several versions of MPTool that I found online but this was as far as I had gotten (see pics). Any help greatly appreciated. Thank you.
 Post subject: Re: Modifying firmware on HP SSD M700 using MPTool?
PostPosted: January 15th, 2020, 6:36
As far a I know MP tools don't dump firmware, just writes it
PostPosted: January 15th, 2020, 7:20
Any suggestions then?
PostPosted: January 17th, 2020, 11:22
Cavaet is that I haven't used MP Tool for anything serious as 1) I don't trust them(myself with them?) and there is no real documentation worth its salt to be 100% confident that I wouldn't kill the drive.
I don't know if there might be a different password/passcode for the MP Tools that will allow editing the serial or not, I think some SMI or Phison have different user level codes.
There might be other things you need to do for the tools such as drivers or some factories have hardware that is a requirement of the tools working properly. Not even sure if serial is available to change in MP Tools, but I think so.
For the picture that has the flash error, this might be just you need to find the right version of MP Tool that has your flash in the config/database file... such as a later version
Users browsing this forum: No registered users and 120 guests
