 Post subject: Is there a SuperLab for desesperate case/customer ?
PostPosted: January 16th, 2020, 6:33
Recently, I had a couple of scratched disks (small or big scratches), I couldn't retrieve any data. I asked another well know Lab, same result.
One customer asked me if there was someone on earth who could retrieve a part of it, I said no. This is probably the best place to ask, so I assume the answer is "no" but problem occurs when you "assume", so I am sure with all the professional on this forum, I'll get the final answer.
Is there a Lab specialized for scratches/desperate cases ?
Sam
 Post subject: Re: Is there a SuperLab for desesperate case/customer ?
PostPosted: January 16th, 2020, 14:16
maybe this can be of some use for you
https://forum.hddguru.com/viewtopic.php ... de#p230359
https://forum.hddguru.com/viewtopic.php ... de#p229512
http://www.mratek.com/MRA/Products.html
https://www.gillware.com/
https://youtu.be/mXDKjwFXC1o
My firmware database:
PostPosted: January 16th, 2020, 16:10
i work a lot with damaged platters, with good rates, but of course i woN't be able to recover data from the filter, so the question is how much it is damaged.
And another question is what kind of data do they need, because there are some data structures not very tolearant to missing fragments (like databases), while others might be useful even if it is a partial recovery.
PostPosted: January 16th, 2020, 16:24
I have 3 drives, they looking for document (Excel, Word) or pictures. The filter are clean. If you contact me in PM, I can tell you who tried so you can tell me if you want to try.
PostPosted: January 16th, 2020, 16:30
michael chiklis wrote:
Thank you very much, I really appreciate your help. My customer probably will try. I will let you know result.
PostPosted: January 17th, 2020, 12:49
I am Also Very Good With Platter Damaged Cases ,I Have Worked With Many Drive Familes And Have My Own Custom Tools Also
Users browsing this forum: Google [Bot] and 161 guests
