 Post subject: ST31500341AS 1.5TB CC1G firmware smartctl ST_M13FQBL 4.14GB?
PostPosted: January 21st, 2020, 21:18
I had this drive die on me with the click of death. Ordered an identical drive as well as head parking tools to do a head swap. The head swap seems to have worked. However now the drive is reporting with an odd model # in smartctl data as follows:
[root@home ~]# smartctl -a /dev/sdb
smartctl 6.5 2016-05-07 r4318 [x86_64-linux-4.16.11-200.fc27.x86_64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     ST_M13FQBL
Serial Number:    QNR_BFW
Firmware Version: 1117F38F
User Capacity:    4,142,054,400 bytes [4.14 GB]
Sector Size:      512 bytes logical/physical
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ATA/ATAPI-6 T13/1410D revision 2
Local Time is:    Tue Jan 21 19:08:08 2020 CST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Read SMART Data failed: scsi error medium or hardware error (serious)
=== START OF READ SMART DATA SECTION ===
SMART Status command failed: scsi error medium or hardware error (serious)
SMART overall-health self-assessment test result: UNKNOWN!
SMART Status, Attributes and Thresholds cannot be read.
Read SMART Error Log failed: scsi error medium or hardware error (serious)
Read SMART Self-test Log failed: scsi error medium or hardware error (serious)
Selective Self-tests/Logging not supported
I did a board swap along with it. So I'm guessing from reading some other threads along these lines I'm going to have to break out my console tools and send some low level commands.
If I am on the right path, could someone help me out and point me in a further direction? I am not afraid of the technicality. I have my trusty bus pirate standing by. Just want to make sure I'm doing the right things to get back up and running.
 Post subject: Re: ST31500341AS 1.5TB CC1G firmware smartctl ST_M13FQBL 4.1
PostPosted: January 22nd, 2020, 18:22
Don't swap the boards if the heads are the problem. Swap the serial flash chip if you definitely wanna swap the boards.
But if it did not work after head swap with native board odds are faint to get it work by pcb swap...
PostPosted: January 22nd, 2020, 20:36
I don’t have the old board anymore. Lost it. How do I get the replacement board working? That is my question.
PostPosted: January 23rd, 2020, 3:39
Assuming you've not transferred the ROM from the old board and you've lost that chip along with the old board, then it's game over. Sorry :-(
PostPosted: January 23rd, 2020, 7:10
almost game over...
Without the content of that sfl chip it is very difficult to recover this drive, i only know one guy able to do that...
Sean, you may also know him :)
PostPosted: January 23rd, 2020, 14:13
pepe wrote:
almost game over...
Yes I do! :-)
But yes, I should have said “game over” for DIY!
