 Post subject: Full FW using PC3K SAS
PostPosted: February 3rd, 2020, 9:13
Hi Guys,
I bought a PC-3000 SAS recently and new to it.
Would you please guide me how to make a full FW copy of a HDD and upload it on another one?
Assuming that both HDDs are exactly the same Seagate SAS.
 Post subject: Re: Full FW using PC3K SAS
PostPosted: February 3rd, 2020, 15:15
I think you don't know exactly what you want to do....
What's your idea?
ACELab partner
PostPosted: February 4th, 2020, 3:48
What's your idea?
Let me explain, then that might help
I have 2 identical new Seagate HDDs and as I said before, I'm new to PC-3000 SAS. I have started training and working with different options. I do not know what exactly I did with FW of a HDD which has got faced errors and malfunction.
Then I've tried to get a full FW copy from the healthy HDD and upload it to the one which I explained above. but no success. Maybe because I am new to PC-3000, I am doing the process wrong.
I really appreciate teaching me how to solve this case.
PostPosted: February 4th, 2020, 5:43
_root wrote:
What's your idea?
Are you writing FW from healthy drive to the Problem/defected drive? and expecting it to work?
PostPosted: February 4th, 2020, 6:01
Are you writing FW from healthy drive to the Problem/defected drive? and expecting it to work?[/quote]
Yes,
As I messed up with the FW, so, I am trying to replace it with the FW of the healthy one.
Hope it works.
PostPosted: February 4th, 2020, 6:46
@_root
This is not how it works with hard drives. Many modules are unique and cant just be replaced.
Its not like flashing a mobile phone, its more complicated.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: February 4th, 2020, 9:54
digisupport wrote:
@_root
Would you plz let me know how to do it?!
Any help is so appreciated
PostPosted: February 5th, 2020, 4:44
If you check the firmware modules, the PC3K utility will tell you if that module is unique or not, or if you can use that module from a donor.
You should inspect that better.
ACELab partner
Users browsing this forum: No registered users and 106 guests
cron
