 Post subject: SAMSUNG ST2000LM003 PCB 100731207 - NO VOLTAGE
PostPosted: February 6th, 2020, 12:10
NO SPINUP.
1. TEST POINTS PLEASE
2. CAN I USE 100739392 AS REPLACEMENT PCB?
 Post subject: Re: SAMSUNG ST2000LM003 PCB 100731207 - NO VOLTAGE
PostPosted: February 6th, 2020, 15:53
There are 3 inductors above the SMOOTH chip. They will be Vcore and Vio. Also measure the voltage at the 2R2 inductor.
I can't tell if the diode is a TVS diode or if it is connected to the coil.
PostPosted: February 8th, 2020, 6:09
used this pcb 100739392 with rom transfer, problem solved
PostPosted: February 8th, 2020, 6:32
Joke:
An electronics enthusiast would say "the problem was not solved, rather circumvented".
PostPosted: February 8th, 2020, 15:40
Try that on an SSD.
Users browsing this forum: No registered users and 75 guests
