Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Seagate SSHD 1 TB ST1000DX001 (FW: CC41) don´t spin.
PostPosted: February 12th, 2020, 18:51
If the procedure does not work, then this would suggest that there is something in the adaptive sections that is getting in the way. The next step would be to transfer the adaptives one at a time, and then see if the donor still spins.
PostPosted: February 28th, 2020, 20:13
lastmile wrote:
I put a PCB from an HD donor in some PCB pacient and they spin perfectly, no clicks or weird noises.
What firmware version on the donor card? I see CC43 on some units.
PostPosted: February 29th, 2020, 11:54
lastmile wrote:
My case is very similar to this: https://forum.hddguru.com/viewtopic.php?f=1&t=29046
What should I do ?
After ROM chip transfer the disk spins up fine, detected in BIOS ...
I be tempted to try the same and if this works re-burn all the ROM chips with a programmer
The chips are 50c each
Users browsing this forum: No registered users and 137 guests
