 Post subject: List of Donor PCB's
PostPosted: February 20th, 2020, 11:10
Hi Friends
Recently I was stuck up with some cases due to non availability of donor pcb's.
I thought if I get a list of typical pcb's from seagate / WD that will be of great help to check missing models .
starting from rom implementation 80GB seagate /WD SATA till 1 TB , if someone has following type of excel sheet that will be of very much use.
