 Post subject: WDC WD10EZRX-00L4HB0 Detect Problem
PostPosted: February 17th, 2020, 13:35
Hi I have this drive and has no detect at all and no strange noise
So I many time try to load loader but I cant get detect , any solution?
this is log of mrt i try to load loader from own drive
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 3
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: A5C0
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 01.3DG
ROM generation : ...............................: 01.3DG
Link table version : ...........................: 22.34
ROM Firmware version : .........................: 0001003D
ROM Modules:
Flash ROM dir reading : ........................: OK
The SA entry address : .........................: closed
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x2
heads map : ....................................: 0,1
load 01...
load 01 to HDD RAM...
The data source : ..............................: HDD
Get 01 module from HDD : .......................: OK
Load module list : .............................: OK
Load LDR(0x5C), As permanent overlay...
Send Data(0x5C) : ..............................: OK
Load LDR(0x11), As permanent overlay...
Send Data(0x11) : ..............................: OK
Load LDR : .....................................: OK
Load 02 module to HDD RAM : ....................: OK
Open SA access ...
Get SA access information : ....................: OK
Check SA access data : .........................: OK
Open SA access : ...............................: OK
 Post subject: Re: WDC WD10EZRX-00L4HB0 Detect Problem
PostPosted: February 18th, 2020, 14:21
Did MRT recognise HDD IDs?
Could you read modules?
Did you test SA modules health?
My guesses
ROM not original
Modules manuplated before
Some modules bad or wrong
Weak head 0
Sexy Womans from your town
PostPosted: February 18th, 2020, 14:43
Ever try to open SA access?
PostPosted: February 19th, 2020, 3:44
ROM is original and hard is intact before costumer came to me.
I do not have detect and ID at all
So first short read channel by short TV9 TV10 and close SA , then try to load loader with " Load 01 Module into HDD RAM "
This is the routine procedure for most case in WD hard drives that dont have detect and ID, and in most of them it get to repair them very well.
In this case I can get to read modules after load 01 Module , but after load 02 drive go to busy which is weird!
Module.zip [4.76 KiB]
Downloaded 387 times
PostPosted: February 19th, 2020, 15:07
There are bad sectors in mod01 I guess
PostPosted: February 20th, 2020, 12:16
This from my module?!!
PostPosted: February 20th, 2020, 13:54
check yours
PostPosted: February 20th, 2020, 18:14
I checked , nothing unusual, could u explain more?
PostPosted: February 21st, 2020, 12:59
Anymore advice guys, I really need to get user data
PostPosted: February 24th, 2020, 10:47
In ID mode and ABA mode all modules are OKay, but in Tracks mode almost all module are zero or incorrect values.
Some of modules in tracks mode
Any advice ?
PostPosted: February 24th, 2020, 15:30
its time to get remote help on this one, is ROM native on this drive ?
Modules reads ok but header incorrect explains alot.
Data Recovery Pakistan
PostPosted: February 25th, 2020, 2:44
ROM is Native.
PostPosted: February 25th, 2020, 3:41
Ask drive owner
"Has he ever tried to connect with non notive PCB over Sata or USB. "
PostPosted: February 25th, 2020, 4:24
HddDonorMarket wrote:
Ask drive owner
No he Didnt do anything or change anything in drive.
Users browsing this forum: No registered users and 88 guests
