 Post subject: eMMC / eMCP NAND adapters without soldering - READY !
PostPosted: September 13th, 2018, 3:55
Hello guys,
As you know first was microSD (https://forum.hddguru.com/viewtopic.php?f=15&t=35872), then SD (https://forum.hddguru.com/viewtopic.php?f=15&t=36364) and now after over 6 months (exactly almost 8 ;)) of hard work and many , many.... many hours spended on reverse engineering, proobing with LA, creating prototypes, testing we want to anounce officially that new series of MR adapters for readign eMMC/eMCP memory over NAND was released !!!!
What raster of eMMC / eMCP are supported (informaiton what are raster look below iun FAQ)
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Chips / Pinouts supported at the moment (pinouts / chips support are realised over sockets - check FAQ)
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
FAQ:
Q: What are those and what for ???
A: Adapters as a standard comes with pogo pins for connection with technological pins on eMMC or eMCP for choosed raster.
Q: What is raster ?
A: Raster it's localisation of technological pins on card - many cards can use same raster but doesn't mean that it will use same pinout. Similar as with microSD - there are cards that looks similar but using diffrent pinout.
Q: OK - I know what is raster but how I can know which one for my card ?
A: Thats why we are releasing sockets/pinouts that fits to exactly chip - for example if you will get Toshiba chip THGBMGBG7D2KBAIL you will know that you need adapter MR10 and pinout/socket 1 as shown here:
After this you will only put socket onto adapter and you can read as shown here:
Next sample ? Let's say you got IC H26M31001HPR which uses TYPE 8, pinout 2 socket like here:
So you will need take TYPE 8, pinout 2 socket from available 4 pcs of sockets for TYPE 8 eMMC
and simply attach into adapter, after installing for reading using VNR it will looks like this:
Simple as never been before ;)))
Q: What are those for ?
A: Adapters allows to solderless connection to demaged eMMC (by chipoff process, controller corruption, or mechanical demage) for data recovery using such tools as PC3000 Flash, Rusolut VNR or Soft Center Flash Extractor. In case
Q: Can those be used in Forensic cases ?
A: Yes - in case of demaged eMMC which are not initialized correctly, showing only 32Mb, got demaged CID or are dead you got nothing other that accessing data over NAND. Due this you will get access to Garbage Blocks and Unprovisoned Area which are not available for any forensic tool.
Q: If I buy 1 of those are I able to recover my data ? You will help me ?
A: Please note that our company offers adapters for solderless reading - we can help in case of settings for correct reading, connection issues but those adapters replace solderign only and give you READY PINOUUT configuration without need to use Logic Analyzer to find correct pinout. So it's first step to read contest of dead chip. Data recovery from monolith devices are more complicated that reading data over ISP or normal ChipOff. You will need to remove XOR (Wear leveling), fix ECC, assembly correctly image to get RAW which you can then use for see real data. If you are not familiar with those task contact us or any other company which works in flash recovery.
Q: Where I can test ?
A: You can visit our company to see them, test reading on your Chip withtou any problem - in few days we will add YouTube videos so you can watch readign process using diffrent NAND readers too.
Q: Where I can buy them ?
A: All those are available on our page on below links:
MR NAND adapters - https://multi-com.eu/shrt-eMMC-NAND-adapters
Sockets / pinouts - https://multi-com.eu/shrt-eMMC-NAND-sockets
While we think that list of adapters will be static since cover 90% of chips used in Mobile Phones then list of sockets/pinouts will grows - soon new models ;)
Q: OK all clear... so will be there anything more ??
A: Yes....... UFS ;)
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
 Post subject: Re: eMMC / eMCP NAND adapters without soldering - READY !
PostPosted: September 13th, 2018, 10:53
Wow! Great job!
PostPosted: November 10th, 2018, 12:28
Hello guys,
At https://multi-recovery.com/models.php we updated list of supported ICs in case of eMMC/eMCP for each model available. Also addedd photos of new microSD, SD which was tested and working with our adapters ;)
Best regards,
Boguslaw Rzepka,
PostPosted: November 18th, 2018, 9:19
Video test from using MR eMMC NAND adapters on:
- VNR
- VNR eMMC NAND
- FE / NR
- PC3000 Flash
Link: https://www.youtube.com/watch?v=lWsG9Dr4sKo&t=9s
Since some ask to get supported pinouts in one place we put it below:
MR NAND adapter for eMMC memory - MR TYPE 1 (Samsung BGA153)
- KMVTU000LM B503
- KMS5U000KM-B308
- KLM8G1GEAC-B001
- KLM4G1YEMD-B031
- KLM4G1FE3B-B001
- KLM8G2FE3B-B001
- KLMAG4FE4B-B002
MR NAND adapter for eMMC memory - MR TYPE 2 (Samsung BGA169)
- KLMAG4FEJA-A001
- KMV3U000LM-B304
- KLMCG8GE4A-A001
- KLM8G1WE4A-A001
- KLMAG4EEHM-B101
MR NAND adapter for eMMC memory - MR TYPE 3 (Samsung BGA153)
- KMVUS000LM-B304
- KMJJS000WM-B409
- KMSJS000KA-B308
MR NAND adapter for eMMC memory - MR TYPE 4 (Samsung BGA153)
- KMV3W000LM-B310
MR NAND adapter for eMMC memory - MR TYPE 5 (Samsung BGA153)
- KML5U000HM-B505
- KMJ5U000WA-B409
MR NAND adapter for eMMC memory - MR TYPE 6 (Hynix BGA221)
- H9TQ64ABJTMC
- H9TQ64A8GTMC-528Y
- H9TQ64A8GTMC-624Y
- H9TQ64AAETMC-710A
- H9TQ17ABJTMC-632A
MR NAND adapter for eMMC memory - MR TYPE 7 (Sandisk BGA153)
- SD5DH26A 4G
- SDIN7DU2-16G
- SDIN7DU2-8G
- SDIN7DP4-32
- SDIN8DE4-16G
MR NAND adapter for eMMC memory - MR TYPE 8 (Hynix BGA153)
- H26M52103FMR
- H9DP32A6AJAC
- H9DP32A4JJBC
- H26M31001HPR
- KE4BT4B6A
- H26M52002EQR
- H26M64003DQR
MR NAND adapter for eMMC memory - MR TYPE 9 (Samsung BGA221)
- KMQN1000SM-B316
- KMR310001M-B611
- KMQNW000SM-B316
- KMQ310013M-B316
- KMQN10006B-B318
- KMQ7X000SA-B315
- KMQ820013M-B419
MR NAND adapter for eMMC memory - MR TYPE 10 (Toshiba BGA153)
- THGBM5G5A1JBAIR
- THGBMFG8C4LBAIR
- THGBMBG7D2KBAIL
- THGBMBG8D4KBAIR
MR NAND adapter for eMMC memory - MR TYPE 11 (Toshiba BGA153/169)
- THGBMAG7A2JBAIR
- THGBM5G7B2JBAIM
MR NAND adapter for eMMC memory - MR TYPE 12 (Hynix BGA162)
- H9TP32A4GDBC
- H9TP32A8JDBC
- H9TP65A8JDMC
Best regards,
Boguslaw Rzepka,
PostPosted: March 13th, 2019, 15:54
Small update to thread to not create new one.
New converters for our MR eMMC NAND adapters are ready which allows to use them on eMMC NAND Reconstructor addon (https://multi-com.eu/,details,id_pr,221 ... tools.html). As you know or not eMMC NAND addon uses DIFFRENT CUSTOM pinout from standard VNR. By this you require special converters which can change pinout of adapter to work with this addon. By using this converters you will be able to use eMMC NAND MR adapters on:
- VNR
- VNR eMMC NAND addon
- FE
- PC3K
Sample photo of adapter:
Adapter after installation:
Video of conection process on diffrent eMMC - https://www.youtube.com/watch?v=ZNfELM3yRMs
Best regards,
Boguslaw Rzepka,
PostPosted: May 13th, 2019, 12:52
Small update to thread to not create new one to our MR adapters which can works with:
- VNR
- VNR eMMC NAND (require converters - click for available models this https://multi-com.eu/,browse,id_gr,1945,key,converters-mr-emmc-nand-for-reconstructor,smenu,forensic_tools.html)
- FE
- PC3000 Flash v4 (available connections board for Standard addon, MultiBoard, Spider)
- Z3x NAND
- more connections boards for other NAND readers coming soon......
Monoliths News
NAND adapter for eMMC / eMCP memory - MR TYPE 13 (Micron BGA221)
Supported models:
NAND adapter for eMMC / eMCP memory - MR TYPE 14 (Hynix BGA162)
Supported models:
From new NAND pinouts for MR adapters:
Socket for eMMC NAND adapter - MR TYPE 7 PINOUT 2
Image Image
Socket for eMMC NAND adapter - MR TYPE 7 PINOUT 3
Image Image
Socket for eMMC NAND adapter - MR TYPE 7 PINOUT 4
Image Image
Best regards,
Boguslaw Rzepka,
PostPosted: September 6th, 2019, 4:16
New adapter !!!! More cooming next week ;)
MR NAND adapter for eMMC / eMCP memory - MR TYPE 15 (Samsung BGA280) offers not only NAND technological access but also read over normal SD reader via SD protocol (watch https://youtu.be/N2iX-5qbIao)
Supported eMMC chip:
BGA280 found in Samsung Galaxy Alpha
Adapter photo:
NAND pinout socket:
Video from us of adapter - https://youtu.be/N2iX-5qbIao
Link to offer: https://multi-com.eu/shrt-uQZOFZG
Best regards,
Boguslaw Rzepka,
PostPosted: January 9th, 2020, 11:24
NEW Socket for eMMC NAND adapter - MR TYPE 8 PINOUT 5 and 6 allows to support H26M42001FMR (two channels) eMMC chip using Type 8 adapter.
Product photos:
Supported chips:
Link: https://multi-com.eu/shrt-8Ua22HSQJ
Best regards,
Boguslaw Rzepka,
PostPosted: February 24th, 2020, 11:04
NEW Socket for eMMC NAND adapter - MR TYPE 8 PINOUT 7 allows to support H26M42003GMRA, H26M42003GMR and H26M31001GMR eMMC chip using Type 8 adapter.
Adapter photo:
Supported models:
- H26M42003GMRA
- H26M42003GMR
- H26M31001GMR
Link to shop: https://multi-com.eu/shrt-DNrRdfkvv
Best regards,
Boguslaw Rzepka,
PostPosted: February 24th, 2020, 17:13
What does it connect to ... PC-3000 Flash ..?
did they post a price for it..?
PostPosted: February 24th, 2020, 17:17
Its all available via the link in the post.
PostPosted: March 11th, 2020, 10:31
New eMMC NAND Type 16 adapter allows to read SanDisk BGA162 over NAND !!!
Supported Models:
SD7DP28C-4G
SD7DP28C-4G
Description: https://multi-recovery.com/subpages/MRTYPE16.php
Link to shop: https://multi-com.eu/shrt-EAClk4GtC
Best regards,
Boguslaw Rzepka,
PostPosted: October 28th, 2020, 9:07
New MR NAND adapter for eMMC / eMCP memory - MR TYPE 17 (Toshiba BGA153)
Supported chip:
SD7DP28C-4G
SD7DP28C-8G
Available pinouts at the moment for support SD7DP28C-4G and SD7DP28C-8G (more can be addedd by cheap sockets in futures)
Description: https://multi-recovery.com/models.php
Link to shop: https://multi-com.eu/shrt-p7wO0bYRP
Best regards,
Boguslaw Rzepka,
PostPosted: November 4th, 2020, 7:26
NEW !!! NEW !!! NEW !!!
MR BGA153 SDIN (Sandisk eMMC) NAND adapter
Photo:
Supported Models:
SDINADF4-⁠128G; ID: 45 48 9b a3 7e; 1x128GB
SDINBDA4-⁠128G; ID: 45 48 9a b3 7e; 1x128GB
SDINADB4-⁠64G; ID: 45 3e ab 92 7e; 1x64GB
SDIN9DW4-⁠64G; ID: 45 3c 96 93 7e; 2x32GB
SDIN9DW4-32G; ID: 45 3a 95 93 7a; 2x16GB
SDINADF4-⁠32G; ID: 45 3c 99 a3 7a; 1x32GB
SDINADS2-⁠32G; ID: 45 3c aa 92 7e; 1x32GB
SDIN9DS2-⁠16G; ID: 45 4c a9 92 7a; 1x16GB
More info: https://multi-recovery.com/subpages/MRBGA153SDIN.php
Link to shop: https://multi-com.eu/shrt-9VHSKy8xq
Best regards,
Boguslaw Rzepka,
Users browsing this forum: No registered users and 87 guests
