 Post subject: Help with removing self encryption on a SAS drive
PostPosted: March 3rd, 2020, 7:17
I am trying to flash firmware onto a SAS HDD, however I believe SED is my problem and not allowing this, what do I need to disable the self encryption on the drive?
I am running CentOS and the drive is ST6000NM0034.
Any advice is much appreciated.
 Post subject: Re: Help with removing self encryption on a SAS drive
PostPosted: March 3rd, 2020, 10:08
How are you trying to flash the firmware?
PostPosted: March 3rd, 2020, 11:25
I am using sg_write command, I have flash quite a few different drives, a lot with success and 1 type of drive which loosing the capacity however this drive 'ST6000NM0034' I am just getting a response back and I believe it is due to the self encryption on the drive;
Write buffer cmd: 3b 05 00 00 00 00 19 60 00 00
write buffer: Descriptor format, current; Sense key: Illegal Request
ASC=26, vendor specific qualification ASCQ=99 (hex)
Descriptor type: Field replaceable unit
code=0x3f
Descriptor type: Vendor specific [0x80]
00 00 00 00 00 00 00 00 00 00 00 00 00 00
bad field in Write buffer cdb
I hope this answers the question :)
PostPosted: March 3rd, 2020, 11:33
I have not worked on this particular drive, but most newer Seagates have a 'locked' PCB and Firmware which prevents any access to the drive. Looks like yours may be one of those.
PostPosted: March 3rd, 2020, 12:57
Is there anyway to unlock the PCB if that is what the issue is?
Users browsing this forum: No registered users and 64 guests
