 Post subject: Resume task failed
PostPosted: March 16th, 2020, 10:00
Hi
I have a situation here, when I was imaging a SSD. In this case I had to put it into safe mode, load a loader, create a translator and start an Imaging task.
During the Imaging, the system crashed and I had to reboot the PC.
After that, and re-doing all the steps to access data, when I want to resume the imaging process I get an error that I attach.
If I create a new task, I can see that the ID of the SSD is exactly the same. If I copy all files from one task to another except task.prm, I can see the sector map (green and black sectors), but on the task statistics all sectors are marked as not read.
If I copy the task.prm I get the same error.
I don't want to re-do all the scan (it took a few days to do....).
Any suggestions?
ACELab partner
 Post subject: Re: Resume task failed
PostPosted: March 16th, 2020, 10:08
pclab,
It is necessary to recalculate statistics on the lower tab "Heх"
PostPosted: March 16th, 2020, 10:13
Tomset wrote:
pclab,
Hi Tomset
In the Hex tab? It's nothing there.
Do you mind to explain?
Thank you so much
ACELab partner
PostPosted: March 16th, 2020, 10:27
pclab,
Sorry, the "map" tab - right click.
PostPosted: March 16th, 2020, 10:28
Ah, found it.
For former knowledge here's the attachment.
ACELab partner
PostPosted: March 16th, 2020, 10:29
I think he meant the map tab, but if you copied the map files you should be able to see the already copied sectors in the map... at least that's what i would expect.
PostPosted: March 16th, 2020, 10:36
pepe,
It is expected, but will not appear until it is counted to a new database. :)
PostPosted: March 16th, 2020, 10:49
even if you copy the fdb as well?
ps.: it looks like we relpied quasi simultaneously :)
PostPosted: March 16th, 2020, 11:53
I also thought it would work just with the copy, but it only worked after the Recalc.
ACELab partner
PostPosted: March 16th, 2020, 11:59
IMHO.
The new task does not recognize someone else’s base.
Users browsing this forum: Google [Bot] and 70 guests
