 Post subject: Lacie drives - confused about AC adapters
PostPosted: March 17th, 2020, 13:19
I have 2 Lacie drives unused for many years but I don't know which power supply goes with which drive! There is only 1 amp difference - does that matter?
Anyway, the 2 drives are:
Lacie d2 Quadra V3
Model number: LAC301549EK
Lacie d2 USB3
Model number: LAC301526
and the 2 power supplies are:
WA-36A12
LaCie PN:AP 713707
output: 12v 3A
WE-24E12
LaCie PN:AP 713709
output: 12v 2A
Which goes with which?
Thanks.
 Post subject: Re: Lacie drives - confused about AC adapters
PostPosted: March 17th, 2020, 13:46
It's not important.
If you plug the 3A on a drive that only requires 2, it will use those 2A and that's fine.
But, if I remember this right, 2A are the usual on all drives, so it will be OK.
ACELab partner
PostPosted: March 18th, 2020, 2:31
Lacie d2 Quadra V3
Lacie d2 USB3
WA-36A12
LaCie PN:AP 713707
output: 12v 3A
WE-24E12
LaCie PN:AP 713709
output: 12v 2A
Thanks.
Use the 2A for the single drive
3A for the two drives unit (if the storage unit uses 2 drives inside)
PostPosted: March 18th, 2020, 3:14
I have a WD 8TB Elements which came with a 12V 1.5A adapter.
PostPosted: March 18th, 2020, 7:03
Einstein9, they are both single drives. The Quadra has 4 outputs: USB3, eSATA, and 2 x Firewire 800, and the other one just 1 x USB3.
Logic would suggest the Quadra is 3A, but I take pclab's point. I am just being ultra-cautious.
PostPosted: March 19th, 2020, 2:43
Most normal 3.5" drive external drives comes with 1.5A, If 2 drives (USB/Firewire...etc they use 2A & 3A)
If you use the 2A for the single drive it should work even the 3A will work
Then When can i use the 3A on a 2A storage?
Well if your storage has for example USB connection which allows connecting EXTRA drives to the unit,
of course the extra drive needs power which tells you here that your Source (3A) should be enough to handle both
hope its clear here
fzabkar is an expert here for electronics troubleshooting & diagnose.
Users browsing this forum: Google [Bot] and 91 guests
