 Post subject: Wd1200BB
PostPosted: April 13th, 2005, 21:50
I got this drive .. everything ok.. SA ---- ok , copy to 60000 sect and then stop ... after that it wont go further .... pick other sector read few thousnads and stop again............ any help will be appreciated
 Post subject:
PostPosted: April 14th, 2005, 8:30
Sorry
 Post subject: Try this
PostPosted: April 14th, 2005, 8:44
Those drives are getting very hot and stop responding. Just put a good fan to the PCB and try again.
 Post subject:
PostPosted: April 14th, 2005, 9:37
This is bad head.
 Post subject:
PostPosted: April 14th, 2005, 9:57
Sorry
 Post subject: a few more words
PostPosted: April 15th, 2005, 3:49
I know very well this model as well as WD800BB, WD600BB and WD400. WD is using the same chip to interface the heads as in the older models. The chip is "overclocked" because the transfer rate is higher and it is getting really hot. I have seen chips that are burnt out. The change of PCB could not help much...
 Post subject:
PostPosted: April 15th, 2005, 8:29
Sorry
 Post subject:
PostPosted: April 15th, 2005, 8:58
About 100-150. Mostly WD400BB (50-60 pcs.). Pretty good statistcs, I think...
 Post subject:
PostPosted: April 15th, 2005, 13:55
Sorry
 Post subject: to Jose Pinto
PostPosted: April 17th, 2005, 3:54
You're right, I'm in this buisness for more than 10years, but as a hobby. I do mainly disk repair (PCB repair to be correct) not data recovery . The market for repaired disk here is poor, almost dead! And disk prices are so low now.... No one can get rich by doing this job...As most of us.
 Post subject:
PostPosted: April 17th, 2005, 5:15
this me again... about that wd1200BB... now have another drive wd200BB... pcb gone, got exact pcb ditto match ... stilll the same problem... cople to exact 6047 sector and then just hang there... so if it is chip it should not get hot withinn few min... i did put a havy duty fan too ... same result...some thing different, i know it is not heads , check ok. pcb is good , SA is good ...must be some thing else, i dont know .....definately something wiered :roll:
 Post subject: To BGman
PostPosted: April 17th, 2005, 6:03
Sorry
 Post subject:
PostPosted: April 17th, 2005, 16:08
did you have done a servo test on your hdd ??i guess its sector servo defects.
 Post subject:
PostPosted: April 18th, 2005, 7:24
IMHO in that case it would surely click. it looks like a translator problem, but I don't have realy much experience with WDs.
Users browsing this forum: No registered users and 60 guests
