 Post subject: ST2000LM015 - How do I get started?
PostPosted: April 14th, 2020, 16:16
I have this laptop that I use daily, but Sunday received a Windows 10 Blue Screen.
The ST2000LM015 HDD is approximately 1.5 years old and no longer boots.
I replaced the HDD and installed fresh OS.
The drive is still in warranty.
I would like to recover some recent work files if possible from ST2000LM015.
Here are the symptoms:
The drive shows up only for a little while in windows, then disappears.
No clicking and continues to rotate after the error.
I have an older no-name USB 2.5" SATA adapter.
When I connect the drive, it is initially picked up by Windows 10. I can see all my folders in the root of both OS and Data partitions.
After a little less than a minute, I get the "Device Descriptor Request Failed" error from windows and the drive disappears.
Crystal Disk Info can't see the drive because it errors out.
Is there somewhere I can read up on troubleshooting this drive?
Thank you in advance for any help, suggestions or information.
 Post subject: Re: ST2000LM015 - How do I get started?
PostPosted: April 14th, 2020, 17:26
1. if the data is critical take it to a pro who has proper equipment.
2. If you can afford loosing it try cloning it under linux (HddSuperClone, dd or ddrescue).
Doing it in reverse order is not a good idea.
PostPosted: April 15th, 2020, 1:45
Thanks, I'll try to find someone who specializes in that work.
PostPosted: April 15th, 2020, 4:13
There are several members from the States, Doomer in Chicago, quasimodo in Florida, Jono_ats in Atlanta, and others whose username i can't recall, but i think somebody will add people to this list soon.
On the other hand somebody might contact you if you tell us your loc.
Users browsing this forum: No registered users and 251 guests
