 Post subject: WD10JMVW-11S5XS0
PostPosted: April 17th, 2020, 9:15
Hello folks,
wondering if one might be willing to help gather the head map from the rom file attached?
I was able to get the following data by your helpful guides so far, but finding the drives headmap local:physical in the ROM riddles me :roll:
pcb is OK, head #4 seems troublesome. in the process of acquiring a donor drive.
Thanks a lot in advance!
Model: WD10JMVW-11S5XS0
Date: 26 JAN 2013
DCM: EBMTJBK
Product of: Malaysia
PCB Revision: 2060-771801-002 REV A
0:1129/4393
1:10EE/4334
2:10F8/4344
3:1140/4416
foobar.rom.zip [238.81 KiB]
Downloaded 346 times
 Post subject: Re: WD10JMVW-11S5XS0
PostPosted: April 18th, 2020, 7:44
Yes, it is 0 1 2 3 without looking at it.
PostPosted: April 18th, 2020, 13:37
@northwind thanks
PostPosted: April 20th, 2020, 17:23
:lol: :lol: :lol: :lol:
PostPosted: April 20th, 2020, 17:49
Analysing foobar.rom.bin ...
Searching for LDSCs and verifying PCMBlocks ...
LDSC   LDSC    Att   PCMBlock          RAM         size      PCMBlk CS
Start  ID CS        Start -  End     address     RAM / ROM    Exp/Act
    0  5A 05   02     100 -  1F95      12000     1E94  1E94  7EDE 7EDE   OK
   20  01 CB   0C    1F96 -  3FE6   A0800000     2050  2050    DE   DE   OK
   40  02 C1   01    3FE7 -  C95B          0 c   B1E4  8974    CC   CC   OK
   60  03 0A   01    C95C -  CEFC      10FAC c    6CC   5A0    56   56   OK
   80  04 27   03    CEFD -  D119      80220 c    2E4   21C    FA   FA   OK
   A0  05 52   03    D11A -  D30A   10145608 c    2F0   1F0    63   63   OK
   C0  06 76   01    D30B - 2451F   900C8800 c  1E96C 17214    22   22   OK
   E0  07 08   01   24520 - 3C438   90002630 c  20C68 17F18    8E   8E   OK
LDSC   = PM Loader Config String (32 bytes)
ID     = ID byte of LDSC (byte #0)
CS     = Checksum byte or word
Att    = Attributes
PCMBlk = Program Code Memory Block
Exp    = Expected checksum for PCMBLock
Act    = Actual checksum for PCMBLock
c      = compressed PCMBlock
size   = size of decompressed (in RAM) and compressed (in ROM) PCMBlock in bytes
ROYL directory module 0x000B found at 0x3F090
Active directory flag = 0x01
Identifying SA regions ...
Reg#  Reg size    Reg loc
0x00  0x000435C0  0x00000000
0x01  0x000435C0  0x00059D00
0x02  0x000435C0  0x000B3A00
0x03  0x000435C0  0x0010D700
Verifying ROYL modules ...
ID          Size (bytes)         Address    Checksum
dir   hdr    dir       hdr
0001  N/A    00004000  N/A        00011E31             N/A
000A  OK     0000003E  00000200   0003D3C2   00000000  OK
000B  OK     00000169  00000200   0003F090   00000000  OK
020B  OK     00000169  00000200   0003E090   00000000  OK
0030  OK     00000400  OK         0003D400   00000000  OK
0047  OK     00000400  OK         0003DC00   00000000  OK
000D  OK     00000090  00000200   0003F000   00000000  OK
004F  OK     00000400  OK         0003D800   00000000  OK
ROYL directory module 0x020B found at 0x3E090
Active directory flag = 0x00
0x00  0x0002B50B  0x00000000
0x01  0x0002B50B  0x00059D00
0x02  0x0002B50B  0x000B3A00
0x03  0x00000000  0x00000000
0x04  0x00000000  0x00000000
0x05  0x00000000  0x00000000
0x06  0x00000000  0x00000000
0x07  0x00000000  0x00000000
dir   hdr    dir       hdr
0001  N/A    00004000  N/A        00000000             N/A
000D  OK     00000090  00000200   0003E000   00000000  OK
dir  -  Module ID/Size as reported in directory module (0x20B or 0x0B)
hdr  -  Module ID/Size as reported in module's header
N/A  -  Not Applicable
BAD  -  Module has invalid checksum. This may be due to non-existent module.
ROM modules saved to Flash_00\000Bmods and Flash_00\020Bmods
Active directory is 0x0B
Analysing active 0x0A module ...
Head map checksum (Expected / Actual) = 0x0000 / 0x0000 - OK
Number of heads (physical / in use) = 4/4
Head map #1 = 0x0F / 0b00001111
Head map #2 = 0x00 / 0b00000000
DCM = | N | C J K J H C F
      : : : : : : : : : unknown
      : : : : : : : : top VCM
      : : : : : : : ACA
      : : : : : : bottom VCM
      : : : : : HSA
      : : : : media
      : : : preamp
      : : latch
      : base
      spindle motor
Analysing active 0x0D module ...
Firmware Version = 01.01A01
World Wide Name = 50014EE60323D691
Model Number = WDC WD10JMVW-11S5XS0
Serial Number =
Analysing active 0x4F module ...
ROM version = 00030078
Analysing active 0x47 module ...
Preamp values
0  02353513
1  0332151E
2  01375619
3  03354513
4  02200400
5  02200400
Microjogs
0  1129
1  10EE
2  10F8
3  1140
4  0A0A
5  0A0A
Head/Media DCM = KJ
PostPosted: April 24th, 2020, 15:14
@fzabkar appreciate :good:
Users browsing this forum: Google [Bot], skinbob and 198 guests
