 Post subject: Seagate 8TB ABR-error
PostPosted: April 24th, 2020, 13:17
Ok, i have this disk, its a seagate Barracuda ST8000DM004 8tb DISK. Client says it has been dropped to floor.
When i start it in PC3k, it spins up, give 1-2 beebs and spins down. PC3k recognises the disk with correct size, serial etc, but thats it. I managed to do backup of all ID-files
Here is what the log says after it starts.
HDD family detecting...
Tech Key...
Error executing command "En Tech" (ABR)
Family ID: 00
Software can`t control COM port signal level for this USB/COM adapter
Selected family......................... : 00, F3 Arch (common)
Model by ID............................. : ST8000DM004
Tech Key...
Terminal : reply timeout error
Is there a possibility that heads are gone?
 Post subject: Re: Seagate 8TB ABR-error
PostPosted: April 24th, 2020, 13:53
Heads are definitely gone, and most likely media damage too.
The ID is stored on the PCB on these, so that’s why you can see it.
PostPosted: April 24th, 2020, 14:00
Heads must be checked prior powering it up if you have info about it being dropped to prevent further damage. Furthermore it is almost surely locked.
I have a feeling that you have very limited experience with hdds, i recommend practicing on spare hdds, not client's disks.
8TB drives are not the best to start with, i suggest outsourcing it.
PostPosted: April 24th, 2020, 14:28
what do you mean by ID-files ?
as pepe said its better to outsource it.
Data Recovery Pakistan
PostPosted: April 24th, 2020, 14:42
ID pages read by PC3k. nothing important.
PostPosted: April 24th, 2020, 16:30
Thanks. I have basically quit this business, and about to sell my pc3000. But this was a friend asking me to check. I suspected heads to be gone :-)
Users browsing this forum: No registered users and 90 guests
