 Post subject: Need ROM - Seagate U8 Fw: 3.13 ST38410A
PostPosted: April 3rd, 2005, 3:00
Hi board users.
I am looking for Seagate U8 ROM, with firmware version 3.13. The model is ST38410A (8.4gb). This firmware can be read by PC3000.
If anyone have it and can be kind enough to send me by mail ... :wink:
-BR-
rregner@terra.com.br
 Post subject:
PostPosted: April 6th, 2005, 16:18
hi man,
- tell me : which u need "family code " for this drive
8)
 Post subject: Use a soldering iron
PostPosted: April 15th, 2005, 4:56
Just unsolder the BIOS chip from the old PCB and solder it to the new one. It's easy! I have done it many times. It's always hard to find the right FW for Seagate disks... Good luck!
 Post subject:
PostPosted: April 15th, 2005, 5:46
hi,
- find the right FW for Seagate disks...
- it's easy, connect Terminal Seagate to seagate disk, next Hyper terminal from XP and put this command from keyboard
1. ctrl R
2. ctrl C
3. for s/n %
it's all
- unlock passwd , this is hard working, example for Uxx model ST310014ACE.
 Post subject:
PostPosted: April 18th, 2005, 6:24
99none wrote:
hi,
1. ctrl R
2. ctrl C
3. for s/n %
Hi, I tried the above sequence, but it didn't make any sensible things
1 and 2 are clear, but could you pls put some light on the 3. step?
thanx
 Post subject:
PostPosted: April 18th, 2005, 7:01
hi,
- in terminal Seagate
Ctrl R, cert or reset ATa interface
Ctrl C , clear interface ??, give Fw:
T> %
- give y serial number
((VALID Cert Disk Code Detected - Revision # 339
T>Interface task reset
1024k x 16 buffer detected
U5 - 1_Disk    3.39  01-19-01 13:49
                          Power Cycling
ATReset
PMaster
8)
Users browsing this forum: No registered users and 69 guests
