 Post subject: WD My Passport WD10TMVW
PostPosted: May 14th, 2020, 9:30
I have a locked WD My Passport 1TB. It's not purposely locked and i'm trying to open it with a software WD Marvel. But it has to be SATA. How can i change USB to SATA?
Thank you
 Post subject: Re: WD My Passport WD10TMVW
PostPosted: May 16th, 2020, 5:14
I already tried change the ROM USB (in the circle) to ROM SATA, but it stil doesn't detect. What should i do?
File comment: I changed the ROM to this
File comment: The ROM USB
PostPosted: May 16th, 2020, 8:29
Not the chip was removed.
Below U12
PostPosted: May 21st, 2020, 1:01
I tried that, but it's still not working
PostPosted: May 21st, 2020, 1:09
you need sata pcb 2060-771820
PostPosted: May 22nd, 2020, 23:26
Yes, thank you. I successed open the password with WDMarvel software
PostPosted: May 27th, 2020, 5:56
I managed to image SATA HDD, but the result was bad. So, i restored hdd back to original (USB), but it locked again. How do i unlock it again? (E.g. = should i edit the ROM or something?)
Thank You
Users browsing this forum: No registered users and 17 guests
