 Post subject: Seagate partial access Easy trick
PostPosted: May 18th, 2020, 23:26
Hello
I had tried 2 Seagate drive . It's not a general solution.
Drive reading some from starting. And some point all remaining sector's turning red (bad sector)
My solution is easy.
Ex Bad sector starting LBA 10000
Stop action.
Set starting LBA bigger than 10000
Power of /on
Continue job. That's it.
Or
Adjust "Power RESET" reading settings
Tested 2 drives in MRT
...Enjoy
 Post subject: Re: Seagate partial access Easy trick
PostPosted: May 19th, 2020, 3:46
Hm?
What if translator is bad? Usually partial access means something is wrong with translator and in this case your trick won't work.
PostPosted: May 19th, 2020, 9:11
northwind wrote:
Hm?
The best I can tell, the OP is just referring to the issue for some Seagate drives that go stupid when they hit a certain block of sectors and rather than have the algorithim in DE set to repower and skip sectors when it happens, you can do it manually.
For those of us who have been around for a while, this isn't anything new. But, for the new guys to the industry, it is good to know.
But, as you state, that is only for one situation and not for situations where the translator is corrupt or drives where one head stops reading after a certain LBA.
PostPosted: May 19th, 2020, 13:47
or perhaps his AltList is full, and if so, there are other workarounds...
PostPosted: May 19th, 2020, 18:06
Or its a troll....
Users browsing this forum: Bing [Bot], Google [Bot], Greenman and 138 guests
