Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
 Post subject: Help Me To Repair This Hard Dick Please !! ♥
PostPosted: May 22nd, 2020, 13:19
Hello Everyone .... :wink:
Please Help Me To repair This Hard Dick :
Type : HDD Seagate
( I am Not Care About Data I Want Just Fix It )
I Was Try This Method :
https://linustechtips.com/main/topic/96 ... ssword-zu/
But It Is Failed :cry: :cry: :cry:
In The Last Step I See " UNLOCK NOT DONE " ??? I Don't Know way !!! :oops: :oops: :oops:
(This Image Number 3 Not From My Computer It Is Just From Site )
If Any Other Way Please Please Please Tell Me ( I am Not Care About Data I Want Just Fix It )
 Post subject: Re: Help Me To Repair This Hard Dick Please !! ♥
PostPosted: May 23rd, 2020, 8:46
It's a really old drive. They were released in 2009. Surely you can afford a few quid for a new one if you don't want to recover data from it?
PostPosted: May 23rd, 2020, 12:56
Why 2009 How Do You Know That ?? :shock:
PostPosted: May 23rd, 2020, 13:03
The size dates it to some extent and a quick look online will confirm a rough idea of when it was introduced. You can find a more accurate date by entering the date code on the drive into thie website
https://www.bugaco.com/calculators/seag ... e_code.php
PostPosted: May 23rd, 2020, 13:17
Thank You So Much Fro Replay ♥♥♥
Are The 2009 Just Date To Released Not The Age Of This Disk !!!
Ok Ok Now I can Fixed This hard Disk Or Not ??
PostPosted: May 23rd, 2020, 13:25
you could send SECURITY_ERASE_PREPARE and SECURITY_ERASE commands which would erase the data and the pwd. These are std ata commands, i think they are available in MHDD.
PostPosted: May 23rd, 2020, 13:30
OOOOOOOk Bro Thank You So Much For Replay ♥♥♥ .... I Will Try Now And Go Back To Tell You Result :roll: :roll: :roll:
PostPosted: May 23rd, 2020, 13:46
Is This Good Bro ??
Continue Or Stop ?? Please Tell Me
PostPosted: May 23rd, 2020, 18:39
I believe these commands require the user to supply a known password, either a user password (which is unknown) or a master password (which is hopefully still the default).
PostPosted: May 24th, 2020, 4:30
So What Do you Thinking !!! .... What Is The Right Solution ??? :cry: :cry: :cry:
PostPosted: May 24th, 2020, 8:31
Unless you are just doing this to improve your knowledge of hard drives it's not a sensible thing to try and get this drive working again. It's small, very old and can be replaced by a small SSD or SATA drive for not much money.
PostPosted: May 24th, 2020, 12:51
I'm Doing This Because I want Learning More About Hard Disk And Secondly This Hard Disk Not Mine It's His to My Brother ... So Really Really I Want Repair It :o
PostPosted: May 24th, 2020, 13:23
Fair enough...
PostPosted: May 25th, 2020, 4:34
alfarom wrote:
Fair enough...
Thank You ... So What Now :o
PostPosted: May 25th, 2020, 9:02
Have you looked at the SMART data? I don't know if that drive will have SMART enabled given its age but give it a go in Victoria. Reallocated Sector Count and Current Pending Sector are particularly important indicators.
PostPosted: May 25th, 2020, 9:26
Is This ??
PostPosted: May 25th, 2020, 9:36
Looks like it can't read the SMART status. I don't know if that is just because that disk doesn't support it or because it's password protected. You could try CrystalDisk to see if that shows the data. You can download it here..
https://crystalmark.info/en/software/crystaldiskinfo/
PostPosted: May 25th, 2020, 9:50
Is This ?? :o
PostPosted: May 25th, 2020, 10:05
I never trust a disk with reallocated sectors count above zero. The drive is failing and will only get worse. I would never put any data on it even if you get it working. It will soon fail.
This link explains it..
https://harddrivegeek.com/reallocated-sector-count/
PostPosted: May 25th, 2020, 10:21
So Look This Is My Hard Disk :D ... Look At The Reallocated Sectors Count And Power On Hours :o
