 Post subject: almost strange problem on WD5000BMVW-11AJGS4 (fblite)
PostPosted: May 26th, 2020, 4:44
hello everybody
these weeks I am involved with a WD hard drive , the MODEL is : WD5000BMVW-11AJGS4 and the family is FBLITE.
when it was booked in , the only thing that I faced with was HSA failure , I did a head replacement and the drive was detected perfect , I checked the SA modules and backed them up using composite method and started cloning . during cloning i found that there are plenty of bad sectors which caused lots of OFF/ON and also caused a slow cloning procedure . after 3 days the process was stopped , the hard drive was not detected anymore , the head behavior was good (no head clicks) I started to load the original loader , i faced this problem (PERMANENT OVL(11) DATA UPLOADING DEVICE ERROR DETECTED: "VSC ERR OFF TOO LARGE")
then I tried with another loader and I could access the SA modules , I check them , the important ones were red , I tried to fix them , but I couldn't write anything on them , I tried to move them , unfortunately no success was achieved . the SA is full of bad sectors now and I can not repair the important modules neither to move them another place .
if you have experience on such a situation , I will be very appreciated if tell me the tips to solve the problem .
best regards
 Post subject: Re: almost strange problem on WD5000BMVW-11AJGS4 (fblite)
PostPosted: May 26th, 2020, 17:33
Power off/on switching during cloning is rarely needed, i am using it close to never. I guess your donor heads screwed up the sa due to different writing adaptives, so it is hard to repair it now but not impossible. I would not spend a lot of time with trying to repair it, there are better methods of cloning it ...
PostPosted: May 27th, 2020, 8:12
thank you PEPE , I got that .
PostPosted: May 27th, 2020, 11:11
is there any way to repair the SA of the drive ???
or doing the clone procedure ??
regards
PostPosted: June 9th, 2020, 5:30
mojimorady wrote:
hello everybody
... during cloning i found that there are plenty of bad sectors which caused lots of OFF/ON and also caused a slow cloning procedure . after 3 days the process was stopped , the hard drive was not detected anymore ...
Looks like that you didn't checked platters parallelism against HDD body
It is pretty common with external hard drives that
- they dropped or got hit by some mechanical shock
- the spindle now is not perfectly centered and it is NOT forming anymore a perfectly 90° angle with the HDD body
- you begin to clone and you damage the platters surfaces
@ our data recovery lab (Italy) we always check with a laser tool that the platters are spinning on a horizontal and parallel plane with the HDD body
PostPosted: June 9th, 2020, 17:48
I doubt this problem has any relation to wobbling.
Moreover, there is no perfect 90°, just good enough.
I've done quite a few WDs (and external drives in general) and it was quite rare that wobbling caused a significant problem. Of course, when it is significant we need to take care of it.
