 Post subject: wd20nmvw problem
PostPosted: June 8th, 2020, 6:44
drive become ready under PC3000, but when I try to work with WD utility become busy.
If I block SA access and load LDR from SA in kernel mode I can backup resources.
But when I allow SA access and power off/on same behavier.
I try also to replace heads. Same behavier.
Any advice
 Post subject: Re: wd20nmvw problem
PostPosted: June 8th, 2020, 8:18
wrong topic
PostPosted: June 8th, 2020, 11:40
did you already solve the problem ?
Data Recovery Pakistan
PostPosted: June 9th, 2020, 1:53
not jet.
I'm working on this project. There is some progress
PostPosted: June 14th, 2020, 22:34
Banned User
Have you backed up all files from the WD drive? You can repair the drive with ARCO but all data will be gone
