 Post subject: WD External Drive Failure
PostPosted: June 23rd, 2020, 13:21
I have a 2TB WD external drive from a few years ago which has stopped working. Disk Management in Windows shows that all the space is unallocated. If I run WD Data LifeGuard Quick Test, it fails with Status Code = 05 (Failed Electrical test element), Failure Checkpoint = 99(Unknown Test).
Any suggestions on what the issue might be and is there still a way to recover the data from the drive?
 Post subject: Re: WD External Drive Failure
PostPosted: June 23rd, 2020, 17:50
Is the drive making any sort of clicking noise or is it spinning quietly?
PostPosted: June 23rd, 2020, 18:30
I haven't noticed any clicking noises. Seems to be spinning quietly
PostPosted: June 23rd, 2020, 19:06
There is a good chance that it's just a firmware malfunction related to bad sector reallocation that is causing the drive to get stuck busy then. That or maybe just one read/write head failed.
It's probably not a DIY type of situation in either event, but almost certainly can be recovered by a professional data recovery company.
Is the data of any value to you, or just the sort of stuff that would be nice to have back and you can live without?
Users browsing this forum: fouad19764, Google [Bot] and 44 guests
