 Post subject: Seagate Rosewood Busy
PostPosted: June 24th, 2020, 1:38
Good day,
I've this Seagate Rosewood hard drive, it spins up smoothly but does not ID-ed and stays BYS always
Model: ST1000LM035
FW: SBM3
Terminal log
Bad CRC Seg:0x06
LED:0x000000BB FAddr:0x00004A18
Ctrl + Z doesn't work
It will be very much appreciated if anyone here know how to go about it?
Seen SMP flags issue (by Acelab) on Youtube, the terminal error is totally difference from my case.. wondering if this is something I should try?
Thanks in advance.
Best regards
 Post subject: Re: Seagate Rosewood Busy
PostPosted: June 24th, 2020, 3:42
You have to patch rom first in order to unlock terminal.
Than you can edit SMP if your heads are OK, or do it in ram.
But I see "Bad CRC Seg:0x06". So maybe you tried already to patch and something went wrong.
Better contact Acelab.
PostPosted: June 24th, 2020, 6:18
Thanks MasterT. we have not patch the ROM, not sure if customer sent this HDD to other center before.
PostPosted: June 24th, 2020, 10:23
Bad CRC Seg:0x06
that should catch your attention...
it has some problems with RAP.
PostPosted: June 25th, 2020, 4:44
Yep, BootFW is bad.
PostPosted: June 25th, 2020, 10:29
daRecoM wrote:
Good day,
Model: ST1000LM035
FW: SBM3
Terminal log
Bad CRC Seg:0x06
Thanks in advance.
Best regards
It's already been answered on the PC3K forum
You can upload the ROM if you want more details
Users browsing this forum: No registered users and 116 guests
