Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: HTS541010A7E630 (NEWEST MODEL)
PostPosted: December 18th, 2019, 4:34
HTS541010A7E630 spin up but cap=0 not det in mrt & cant read nvram or mlist problem is pcb for fix you must soldering the spindle motor ic & nvram chip just heating that chips for few sec its work for me & det by mrt as basic access whit full cap good luck
PostPosted: June 27th, 2020, 7:40
HTS541010A7E630
Usıng MRT
Selected family:Tech-Key detection
Model:HGST HTS541010A7E630
Technology key : ....................................OK
Reading module list failed,try Copy1......
Read module list : ..................................Error
Read open module list : .............................Error
get the head number : ...............................04
Backuping NV-RAM...
Save Path :C:\UserDataFile\Hitachi-ARM\Tech-Key detection\HGST HTS541010A7E630-SE0OA4A0-S00001SSGTRHRF\Data\NV-RAM\
NV_RAM.nvr : ........................................OK
NV-RAM_0.nvr : ......................................OK
NV-RAM_1.nvr : ......................................OK
NV-RAM_2.nvr : ......................................OK
NV-RAM_3.nvr : ......................................OK
NV-RAM_4.nvr : ......................................OK
Backup NV-RAM : .....................................Complete
Reading ROM
Save path:C:\UserDataFile\Hitachi-ARM\Tech-Key detection\HGST HTS541010A7E630-SE0OA4A0-S00001SSGTRHRF\Data\ROM\
Save ROM : ..........................................Succeed
Drıve ID ok. but 0 capacity
Who knows what is the problem?
HGST HTS541010A7E630-SE0OA4A0-S00001SSGTRHRF.rar [136.44 KiB]
Downloaded 876 times
Sexy Womans from your town
PostPosted: June 27th, 2020, 8:57
Is the pcb native?
PostPosted: June 27th, 2020, 8:58
i recall i had pcb problems with these. Drive spun up but heads did not move or something like that.
PostPosted: June 27th, 2020, 9:57
pepe wrote:
Is the pcb native?
Customer's hdd. But I guess native.
Sometimes at start making 1 click.
Drive working sound nice. Very quickly getting ready status.
If I could find donor, I would change head.
PostPosted: June 27th, 2020, 12:07
does it move heads at all? have you checekd SN in nvram and on label?
PostPosted: June 27th, 2020, 14:24
both yes
PostPosted: June 29th, 2020, 16:21
The tool gives those numbers nonsense because it is not recognizing NVRAM well. In addition, you must be careful with MRTLAB, since with some model if the head map is modified and is left as it was, the NVRAM is altered and may not start the disk again.
PostPosted: May 1st, 2021, 5:38
HddDonorMarket wrote:
HTS541010A7E630
Usıng MRT
Backuping NV-RAM...
Reading ROM
PostPosted: August 12th, 2022, 5:35
The problem is a ROM failure.
1. Make backup of NvRAM from patient drive.
2. Upload NvRAM from DONOR drive to PATIENT drive .The DONOR drive have to be the same fw-microcode.
3. Power reset the patient drive (the patient drive will not spin up, but sends DRDY state for a sec).
4. Upload original NvRAM to patient drive.
5. Power reset patient drive.
This worked for me.
Cheers!
Users browsing this forum: Google [Bot] and 64 guests
