Forum rules
 Post subject: ERROR 4f00 error 4f10 WD
PostPosted: June 28th, 2020, 22:20
Hi, I'm new to the forum and I have some questions and would like to know if you can help me?
Estou com esse erro esse erro da imagem e não consigo fazer nada com o hd no sediv.
 Post subject: Re: ERROR 4f00 error 4f10 WD
PostPosted: June 29th, 2020, 0:09
Palmer Lock.
Need unlock PCB.
PostPosted: June 29th, 2020, 9:54
Can I unlock this in the sediv?
PostPosted: June 29th, 2020, 14:47
Not.
Оnly buy unlocked PCB.
https://www.donordrives.com/unlocked-wd ... drive.html
Or.
Sediv possible if find an unlocked board for a while to unlock your own.
PostPosted: June 29th, 2020, 16:00
Tomset wrote:
Not.
Or.
PCB is more expensive than HD. Can I unlock mine through the sediv?
PostPosted: June 29th, 2020, 16:01
PostPosted: June 29th, 2020, 16:11
Alas.
Without an unlocked board, no matter how.
Already having an unlocked board, you can unlock your own.
You can contact someone who has such an unlocked board and he will unlock yours.
Moreover, he can unlock such a board only a few times. Then he will have to buy a new one.
PostPosted: June 29th, 2020, 17:26
Will I get the unlocked pcb, will I be able to unlock the others by sediv?
Thank you for the time being.
PostPosted: June 29th, 2020, 17:37
Sorry, can you tell me the procedure? To be done as soon as I can?
PostPosted: June 29th, 2020, 17:53
https://forum.acelaboratory.com/viewtop ... 032#p36392
PostPosted: June 29th, 2020, 21:58
Sorry, I disturb you again, but from what I saw in that post, when the pcb blocks, it wouldn't let me do anything with the hd, in my case I see the capacity, I install, record, I just can't clean the smart, give the error I sent in the post. Do you check what I said?
PostPosted: June 29th, 2020, 23:14
renatofls,
In the beginning, you need an unlocked board.
With her help, you can unlock your board.
Аnd not otherwise.
