 Post subject: Flash extractor v6 738
PostPosted: May 24th, 2020, 22:42
hey just wanted to know if anyone has a copy of flash extractor v6 738. pretty sure that's the latest my licence is good for but cant find it anywhere to download.
 Post subject: Re: Flash extractor v6 738
PostPosted: May 26th, 2020, 1:05
uploaded to http://files.hddguru.com/download/Software/FLASH/Flash%20Extractor%20FE%20from%20Soft-Center%20/
I think you can use up to v471 of NR, but if not I also uploaded NR v415 which was downloaded around the same date.
PostPosted: July 1st, 2020, 16:25
hi, im trying to download the Flash Extractor files (any for that matter)
but all files are 'Damaged' or 'Corrupt'...
Do we have any working files?
I bought an PC3000 Firmware extractor.
But as all ali-junk there is no documentation or software help :(
https://nl.aliexpress.com/item/40003108 ... 4c4d72A7HL
PostPosted: July 2nd, 2020, 3:27
That item is just an USB-serial adapter, nothing more. You won't be able to 'extract' firmware using this only.
PostPosted: July 2nd, 2020, 4:37
The title of the product says: "Pc3000 usb lijn com lijn pci3000 st com speciale lijn 2"
who told you that 10$ cable will do the Magic and fixes your problem?
and btw AliExpress is the Amazon competitor #1 .... not a Junk..
PostPosted: July 2nd, 2020, 7:01
Let me clarify this then...
ali-junk = Aliexpress item that sometimes arent working or up-to QC.
Aliexpress Vs. Amazon = Price competitors, And delivery times are way out of league.
No body told me tanything, but as i stated, i need the software to let it function.
thats why i thought that this software would do it.hat the cable would 'solve'
PostPosted: July 2nd, 2020, 7:04
I guessed that the device would be something like this.
But that is why im here trying to find software to make it work.
But all zip's are corrupted so thats a dead end.
and the name if the file hints to me, that it extracts atleast something.
PostPosted: July 2nd, 2020, 12:03
If you wanna use Flash extractor you need their reader as well. BTW, what device do you have? You never mentioned it.
It's gonna be a steep learning curve if you are not familiar with recovering data from flash devices.
consider contacting somebody who's experienced in the field...
PostPosted: September 29th, 2025, 20:02
Okay, maybe noob here, flash extractor does what? data recovery from flash drives? or does it read the firmware? is it even possible to read the firmware?
PostPosted: September 30th, 2025, 2:13
Flash extractor does exactly what it says, it extracts data from the flash memory storage. It's up to the person using it to then get that data into a usable state.
There is no magic one button clicks to fix firmware, etc.
PostPosted: September 30th, 2025, 6:35
a slightly different question, unfortunately Flash Extractor is no longer produced, it cannot be purchased, are there any alternatives besides Rusolut?
PostPosted: October 12th, 2025, 9:56
Ace Labs PC-3000
do NOT even think about Flash Doctor from Salvation Data!
