 Post subject: Change PCB 800069 USB to SATA
PostPosted: July 6th, 2020, 4:18
Hi I dont have PCB 800066, Is there a way to convert 800069 to SATA ? I need to recover data.
 Post subject: Re: Change PCB 800069 USB to SATA
PostPosted: July 6th, 2020, 6:29
siamak5561,
https://forum.hddguru.com/viewtopic.php?f=13&t=40087
PostPosted: July 6th, 2020, 12:03
I dont need to see and edit SA , just want to use data explorer in MRT, So is there a way to change this board to SATA ?
For example like this board https://www.alldataback.com/wd-usb-exte ... interface/
PostPosted: July 8th, 2020, 17:34
Guys any method ?
PostPosted: July 8th, 2020, 18:22
Instead of relying on rote learning, try to understand the principle in that alldataback tutorial, and then adapt it to your particular case.
Here is another tutorial:
https://blog.acelaboratory.com/soldering-of-sata-connector-to-samsung-spinpoint-usb-pcb.html
PostPosted: July 8th, 2020, 23:05
It won't help now, but consider getting a DeepSpar usb stabilizer which works great with MRT. Add UFS Explorer to help with file system imaging and you are on your way.
PostPosted: July 11th, 2020, 4:02
Thanks guys.
I want to know , without unlocked pcb , is there a chance to get data ? and I have to say again, no need to edit SA, just using Data explorer in MRT.
