Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Cutting head from Rosewood
PostPosted: July 7th, 2020, 16:12
Did anyone managed to physically cut head(H0 in my case) from Rosewood and still managed it to calibrate? Guess there's some FW work needed to.
odzyskiwanie danych
 Post subject: Re: Cutting head from Rosewood
PostPosted: July 10th, 2020, 6:32
melvin wrote:
physically cut head
No butchers on this forum....
:shock: :shock: :shock:
PostPosted: July 10th, 2020, 8:21
i usually only lift, the defective heads... but yeah, conceptually it works.
PostPosted: July 10th, 2020, 8:45
BGman wrote:
melvin wrote:
physically cut head
So i'm in a good place...
Thought about lifting too with a little wire or hook.
Just thinking about turning it off in FW.
odzyskiwanie danych
PostPosted: July 10th, 2020, 14:25
If the head is just dead that works, but if the head is touching platter you'll need to lift/cut...otherwise drive dies very soon of all debries.
http://www.rescue-it.se
PostPosted: July 10th, 2020, 14:50
This has recently been discussed on another forum. Several of us have experimented with SMR drives and we found that physically cutting off a head does kill the entire head stack. Maybe there is a secret we missed, but that was the general concensus.
PostPosted: July 10th, 2020, 15:33
I've tested cutting off. Didn't work. Guess more Rosewoods are going to be recycled soon. And I need to test lifting on a working drive.
odzyskiwanie danych
PostPosted: July 11th, 2020, 3:39
sorry but is it worth it? i mean people are buying those?
most of the people will think paying few extra $$ and buy new hdds instead of used
:shock:
PostPosted: July 11th, 2020, 7:14
:shock:
It's not about money.... It's about the pleasure of cutting heads! :lol: :lol: :lol:
PostPosted: July 11th, 2020, 8:23
:shock:
makes sense now...
Thnx for clearing this :beer:
PostPosted: July 11th, 2020, 10:10
einstein9 wrote:
:shock:
makes sense now...
recycled, not refubrished :D
Just trying to find a way to recover Rosewoods with one scratched surface.
odzyskiwanie danych
PostPosted: July 11th, 2020, 17:55
send it over...
PostPosted: July 12th, 2020, 3:01
@melvin
Am not sure about seagate new models now,, but for WD for example it was related to zones and how big is that zone
sometimes 1MB file takes both places H0 & H1 and some times in one head only..
Now who decides where the 1MB file? .... i think its random or probably calculations takes place inside the MCU.... i don`t know
am not sure 100% about my idea here but some how right somewhere (i think)
:wink:
have a good weekend
PostPosted: July 12th, 2020, 4:33
einstein9, When one surface is scrathed and other is good it is better to recover some files than none. If it is possible with WD, HGST or Toshiba it should be possible with Rosewood too.
odzyskiwanie danych
PostPosted: July 12th, 2020, 5:21
Agree with you here,, but probably you did not get my point here
In Seagate H0 ok H1 scratches, when the required file is 1MB for example
sometimes the 1MB file will be in H0 ONLY and sometimes 1/2 of the file on the other head right?
so my point is about the zone size (i think) right?
sometimes we are lucky but some are not (specially when the required file SIZE is big)
correct me if am wrong here..
Thx
PostPosted: July 12th, 2020, 6:42
I got it. Seagate has quite big "zone size" so a lot of Jpegs and docs are recoverable. Second thing that will reduce the number of good files is fragmentation.
odzyskiwanie danych
PostPosted: July 12th, 2020, 7:59
Thnx... :agree:
PostPosted: July 13th, 2020, 15:53
I could be wrong, but I recall Rosewoods having small zones, hence 1TB models with one disk inside, most files won't be recoverable.
PostPosted: July 13th, 2020, 18:27
Rosewoods read several gigs continuously from one head.
This whole thing is not related to zone sizes, coz zones are a lot wider, at least on older seagates, where the continuous areas are called serpents and usually 40-60 physical tracks wide.
PostPosted: July 14th, 2020, 2:53
Because they are SMR. Correct?
Users browsing this forum: Majestic-12 [Bot] and 43 guests
